Safe to powdercoat final drive hub?
Discussion in 'XJ Technical Chat' started by Jmkrull, Mar 31, 2018.
  1. Jmkrull
    Jmkrull Member
    Minneapolis
    Just wondering if it’s safe to cook the final drive hub without completely disassembling it, minus shaft and oil seal out. Anyone know or have done it safely? Thanks.
    Jmkrull likes this.
  3. Toomanybikes
    Tsawwassen bc
    Maybe try VHT paint for brake calipers
    Turns out nice and only requires 200F to cure it.
    Jmkrull likes this.
    Like Xj550H pointed out, there's more than one oil seal, and you have to do a full teardown to get to them all. Reassembly requires making a pair of special tools, and knowing how to use a dial indicator. Best to just clean it up and paint it with a good enamel.
    Jmkrull likes this.
  5. Jmkrull
    Jmkrull Member
    Minneapolis
    Sounds good. Thanks everyone. Once I get the hub on, can I take it off in the future without having to pull the engine again if it needs repainting at some point?
  6. XJ550H
    yes you just disconnect the drive shaft from motor
