SAFETY ALERT Drum rear brake bike owners please take a look
Discussion in 'XJ Technical Chat' started by bigfitz52, Mar 6, 2009.
  1. 750E-II_29Rbloke
    South Cheshire, UK
    Chacal ;) (Len at XJ4Ever, forum's supporting vendor & the best thing to happen to a group of XJ owners since Yamaha deciding to make a bike called an XJ :) )
  2. raptor8
    raptor8 Member
    Bend OR
    I'll be ordering new shoes for mine come spring... I don't like the [lack of] function back there...
  3. bigfitz52
    I love my job.
    You guys rock; makes it all worth while. Seeing 10 pages of responses gives the old Fitz a warm fuzzy.
    Carry on.
  4. Rayjay1959
    Rayjay1959 Member
    Prescott, az
    I put new shoes on my 82 xj750 and also took 80 grit sandpaper to the drum. The stopping power of these rear brakes after the new shoes are only somewhat better than the old shoes. I could probably stand on my rear brake lever and not skid the tire. Is this normal? Is there something I'm missing?They look like u-powered brakes(as in you have to power the brakes with foot force).
  5. Polock
    the new shoes don't match the drum yet.
    if you were to pull them off again you'll see that the whole shoe isn't touching yet. they'll ware in and get better but it takes a while
  6. dirtymike
    dirtymike Member
    Im scared now.
  7. RiceBiker
    RiceBiker Member
    San Leandro, CA
    I ordered new front brake pads when I took off the old ones because I had never seen brake pads shaped like that. |\ \|
    I was going to rebuild the caliper too, until the new pads came in and they were already shaped like that. Weird!
  8. bigfitz52
    You still need to rebuild the caliper, the seals are 30 years old and were only supposed to last 4 years. Master cylinder as well; and replace the brake lines. http://xjbikes.com/Forums/viewtopic/t=41400.html
    The pads are shaped that way because the caliper rotates as the pads wear down rather than sliding side-to-side the way most calipers do.
    This article is a warning in regard to dangerous delamination of the rear brake shoes. Have you pulled yours and visually inspected them?
  9. Taku
    Taku Active Member
    Morganston, Ontario
    Thanks for the notice, excellent advice.
  10. moenza
    moenza New Member
    Alberta Canada
    Here's a link for explanation and find out the age, especially since there might be a few old bike's around with some old tires on it
    which have a slight different production time explanation.
    To be safe, replace any tire over 10 years old, even when it does not have visible cracks, tire shops though can't legally install or
    balance your wheels when tires are over 7 years old, well this is for canada, i don't know the rules for other countries.
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
    As for original forum post, regarding brake lining coming apart, i've seen it lots, my opinion it's mainly age related with moisture
    shortening the timeframe.
    Be safe and check them ! it's a 10 minute easy job.
  11. darren ditmar
    darren ditmar Member
    eugene oregon
    so idk if its my shoes r what but every now and then when i go to use the back brake the lever will go down a lot farther than supposed to with no resist and then will kick in really quickly idk the problem i tryed pulling it apart pads are still in one piece and look ok
  12. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Start a new thread. We can help.
    Gary H.
  13. XJ550H
    the jb weld is a joke NEVER use it to repair brake shoes
  14. rocs82650
    Middle Tennessee
    Is jb weld brake shoes applicable? If it is I wouldn't use it on brake shoes. The cost of a good set of shoes is far less than having old shoes delaminate while riding.
    Gary H.
  15. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    NONONONONONONONO! JB weld is not brake shoes applicable. The post says it is a joke. I think it means he's joking. It also says NEVER (bold, italics, underlined in red) use it to repair brake shoes. I think he means never use it to repair brake shoes.
    In my opinion, there are two ways to deal with delamination: replace them, or die. (Slight exaggeration)
    XJ550H, it would seem that people here do not get your sense of humor... Both times that I have seen you post that pic have sent people in a tailspin! I have a similar problem... Oh well, keep on trying.
  16. rocs82650
    Middle Tennessee
    Oh, ok. I thought he was saying jb weld is a joke and showing a picture of what happened after using it on a set of shoes. FWIW I've used jb weld in a few applications with no hiccups to date. If it was a joke...my bad.
    Gary H.
  17. MattiThundrrr
    Only reason I knew is that he previously posted it in another thread... I probably would have said the same thing if I hadn't seen it. The bold "NONONO" was to emphasize to others that this is a joke. Big Fits was pretty serious when he started this thread, and I respect that. Didn't want bad advice on it for the kiddies... Sorry if I was harsh.
  18. cgutz
    cgutz Well-Known Member
    SE South Dakota
    My 83 XJ550 just got new rear shoes. Originals hadn't delaminated but were thin. New ones have better stoppoing and don't squeel.
  19. Toomanybikes
    Tsawwassen bc
    With the poor quality of the original shoes and I have noticed that many of the bikes that have bad ones seem to be near the ocean = salty moist air causing corrosion lifting the glue from aluminum base.
  20. k-moe
    Mine were delaminating when I got the bike, and there hasn't been an ocean near here for 250 Million years. I've seen delamination on other machines from various manufacturers. They all had one thing in common; age. Time breaks down the adhesive, and if the machine is not used much it will still have the original brake shoes on it. That's not to say that salt air won't accelerate the process.
