Sand in my cracked engine
Discussion in 'XJ Technical Chat' started by Bloodsweatntears, Aug 14, 2019.
  1. Bloodsweatntears
    Bloodsweatntears New Member
    Southern Alberta
    Rain finally stopped got better look at the 82 seca i picked up and PO had pulled the heads and jugs and didnt do a vary good job cleaning and sand got in the crank case any way to flush it or am i rebuilding the whole engine now
  2. chacal
    You're doing this now, or you (or the next owner) will be doing it later...…...
  3. k-moe
    Maybe not rebuild, but definitely disassemble, clean, and inspect every darn millimeter. Maybe, just maybe the sand got in after the top end was removed, and didn't do any harm.
  4. Bloodsweatntears
    Southern Alberta
    Yea it hasnt ran he said he had it running before pulled the heads to do the rings because of low compression in #4
  5. k-moe
    How did he determine that it was from rings being worn (highly unlikely on just one cylinder) and not from a stuck ring or a faulty gauge, or valve clearances being out of spec, or...?
  6. Bloodsweatntears
    Southern Alberta
    I figured it was valve clearance i think he was just gun hoe on rebuilding the top end but didnt clean the motor was bought as a project
  7. Bloodsweatntears
    Southern Alberta
    So in light of this thinking i will part it out unless some one wants to buy it for what i have into it $300 its kinda sad its numbers matching 35k on the speedo but its broken canadian version
  8. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    How much sand is in the oil pan?
  9. k-moe
    Don't part it just yet. Unless the engine was run with the sand in it you will still have a viable engine.
    The oil pan can be pulled off easily, even with the engine still in the frame.
  10. Ryengoth
    Wilmington, NC
    Try to drain it all into the same pan and pull the filter too. If there is no sand in the filter you may be OK. When you are done draining the oil put the plug back in and drop the pan. See how much grit is left in the bottom. Take a paint strainer and filter the oil and see how much sandy material is left in the strainer.
  11. Ryengoth
    Wilmington, NC
    Also, can you get a picture of the cam lobes, cleaned of oil/dirt? If you've disassembled the head it would be good to see how much galling there is on the cam and head journals.
  12. Bloodsweatntears
    Southern Alberta
    I think it fell in when he removed the jugs was still some on there by the studs the oil was drained i can see it on top of the crank. What about flushing with diesel, Or a lighter weight oil?
  13. Ryengoth
    Wilmington, NC
    Flush it with 2-stroke gas. You can filter and reuse it.
  14. Bloodsweatntears
    Southern Alberta
    Whats the best way to flush? Leave oil pan in and flush or pull it and flush into drain pan
  15. Ryengoth
    Wilmington, NC
    I would take the pan off and flush it from the top down if it fell in from the cylinders. If you have a solvent sprayer use it and soak each rod and crank area heavily. You can also use a bucket on a ladder and some 1/4" tubing to make a siphon/gravity fed rinse tool. I would soak everything down several times and then rotate the crank slowly and look for any deposits of sand left.
  16. a100man
    a100man Well-Known Member
    Bedford, UK
    I'm with the flushing. I imagine not much of the debris will simply 'fall' on to bearing surfaces - as oil needs to be pumped in there - right?
    Diesel yes.
