Scrap it or fix it - the crashed '83 XJ750MK
Discussion in 'XJ Technical Chat' started by Ray Wilson, Feb 15, 2023.
Scrap it, or Fix it!?
  1. Scrap that poor bike.
    0 vote(s)
    0.0%
  2. Nah, fix it.
    5 vote(s)
    100.0%
  1. Ray Wilson
    Ray Wilson New Member
    Boyertown, Pennsylvania
    Bored on Craigslist, years ago, bought a 750 Maxim that had been in a wreck. I had heard they were good bikes. Took a gamble, and gave the seller his $400. Upon closer inspection, should have lowballed! Bike had not run since 2013 or so.
    Seller was honest, told me what happened. Bike was running well enough to get it to the scene of the crash. But, boy, was it used and abused before the accident.
    Bike sat in my garage for at least 3 years. Decided to see if it would run. It does! And idles. And revs. And goes into gear. And shifts thru the gears (all on the center stand).
    Hot compression test as shown in the pictures. Makes electricity. Starter works. Turn signals work, what's left of them. Headlight works. Horn works, kinda. Engine sounds funny as one of the headers is GONE. How'd that happen?
    No chance of corrosion, as the engine is coated in oil from top to bottom. For the rest of the bike, many Midnight Maxim only parts are crunched, though. Gas tank is salvageable.
    I half expected to find a deal-breaker, and have the decision to scrap or fix evident for all to see. But, I don't know, I think there is a chance. If I adjust the valves, replace the valve cover gasket, rebuild the exhaust, maybe she'll come around. Thankfully the previous owner quit while he was ahead and only snapped off the two exhaust studs. I subscribe to the use-a-welder to get 'em out.
    Ray
  2. Timbox
    Welcome to the forum. that looks to be a good project bike that will need lots of love. If you have the time, go for it.
    You will need to read a few of the links from the top right of any page. Take the time and read over the cost of one of these bikes. It will take some time to get the bike back on its feet so to speak but you will love working on it.
    Please do a lot of reading and searching on this forum, so much information.
    Those issues you have are not too bad and the compression test also looks not too bad.
    Good luck on the project.
    Jetfixer, Franz and Ray Wilson like this.
  3. Ray Wilson
    Thanks, Tim! Site is a treasure trove of information. And is the reason I dragged black ‘beauty’ out of the garage for a closer look. Valves will be first, although I’ve been tidying up wiring such that I could start the bike to listen for ugly noises. Even the oil change fought me. Stuck/rounded off oil filter cover bolt. But she’s got fresh Rotella T4 in there.
    I’ve already got a replacement handlebar. Big challenge will be sourcing the muffler bits. eBay sellers want silly money to ship those size parts.
    Steering head bearings need to be replaced. There’s a notch the size of the Grand Canyon about dead center. Fork seals are dry, amazingly enough.
    Gauge cluster is trashed, and my be the hardest parts to find. Wish me luck! And thanks for the response.
    Jetfixer and Timbox like this.
  4. Franz
    Ray Wilson likes this.
  5. Ray Wilson
    Franz, that exactly what I needed to get the bolt out! Being cheap, I turned down the ruined bolt head and welded a nut on. Joy!
  6. Ray Wilson
    My previous owner went to the "don't fool with a new o-ring, just crank that oil filter bolt down as tight as you can, then another half-turn" school of thought. 297108111_10210921908519970_1412924781471565492_n.jpg 297211260_10210921908839978_141493933833741967_n.jpg 297450003_10210921909159986_4669929835641488309_n.jpg 297877575_10210921987521945_4596014577518513677_n.jpg 297951603_10210922171446543_7874321460187946348_n.jpg
    Jetfixer, Timbox, Franz and 1 other person like this.
  7. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Nice job.
  8. Franz
    Great repair.
  9. Dan Gardner
    Minneapolis, MN
    Top choice: fix it.
    Second choice: see if you can find somebody else who wants to take on the project and sell it for what you’ve got in to it.
    Third choice: there are some good parts there that you could easily cover your cost
    Nice repair though. For sure. Seems like you probably have the chops to make a quality repair in a reasonable time.
    best of luck! Keep us updated
  10. Ray Wilson
    Thanks, Dan. I sorted out the wiring that mates to the battery, today. Next step will be to extract the broken exhaust studs on Cyl 2. They are broken off about a tenth of an inch below surface.
    Ray
  11. Fuller56
    Fuller56 Well-Known Member
    If you can fix up that filter bolt that nicely you can fix the rest of the bike. We have confidence in you and the staying power the XJ's.
  12. Timbox
    @Ray Wilson
    Looks like you have the skill and tools to do just about anything that might need to be done to the bike. Hope that your enjoy bring her back to life.
  13. Ray Wilson
    Thanks Tim, for my next trick, I’ll see if I can weld nuts on the sunken studs. Although, truth be told, if I have to pull the head, so be it. I don’t have to drive the bike to work next week.
  14. Jetfixer
    Fix it!!! I rebuilt a Seca from an engine and frame bought for 100$ at a swap meet sold it on , recently bought another Seca for 100$ , got it running ,but still messing with wiring . I wrecked my beloved yellow Seca , but have put it back together . Here are pictures the Red bike was my swap meet 100$ special, old yellow, and my latest 100$ special.
  15. Dan Gardner
    Minneapolis, MN
    @Jetfixer - was yellow a factory color? I dig the yellow.
  16. Jetfixer
    The PO painted it that color , I like it as it matches my super beetle.
  17. Ray Wilson
    I like the Beetle Bug, too! I had one. Orange.
  18. Ray Wilson
    …and I need to start going to your swap-meet!
  19. Ray Wilson
    And so the valve clearance quest begins…. I bet these were never checked, adjusted, ever.
  20. Jetfixer
    . I use a piece of Romex bent to a 90 degree angle .
    Be very careful using thus tool , you c an break the casting
    Timbox, Franz and Ray Wilson like this.
  21. Franz
  22. Dan Gardner
    Minneapolis, MN
    Just don’t force it and you won’t break anything
    Guaranteed you will accidentally turn the crank the wrong way occasionally. Just don’t force it
    You will get good at it quickly
    and pay attention to the slot in the bucket where you can kind of pry the shim out. Need to position that before trying to hold down the bucket
  23. Ray Wilson
    Small victory today. Was able to MIG weld on one of the two broken exhaust studs and back it out. Was broken off below flush. One more to go.
  24. Ray Wilson
    …oh, and gas tank de-rust is underway.
  25. Timbox
    Nice, keep on just picking away hit it. You will find it very satisfying and she will be running in no time. that is depending how far you are taking her down for the rebuild.
