Seafoam to remove rust?
Discussion in 'XJ Technical Chat' started by sethoneal7, Dec 7, 2014.
  1. sethoneal7
    sethoneal7 Member
    Dallas Texas
    I was chatting with a gas pump repair guy, I asked him whats the easiest way to get rust out of a gas tank. He says seafoam. Just pour a bottle in the tank. Let it sit. Put some nuts and bolts in it and shake it up. Let it sit in a different position... Shake it up.... And so on and so on. Empty the tank out.. Rinse it with gasoline. If not use distilled water. Fog it with WD-40 and pour some rubbing alcohol to dry it. I'd feel a hell of a lot better about this method than putting other stuff in the tank, like coke or the works... Or sand in it. Petroleum distillates seem to be the least risky to me. If they work. Anyone else tried seafoam like this?
  2. xHondaHack
    Orange CT
    I used Evaporust and followed the same method with great results.
    Not sure how effective the Seafoam would be for that purpose?
    rocs82650 likes this.
  3. Polock
    kerosene is cheaper
  4. Skwerly
    Skwerly Member
    Yucaipa, CA
  5. XJ550H
    still laughing at that thread. I do belive it will work but can not think of how to explain to wife why I was taking her extra pillows or using her dryer.....
    I used fluid film its like pb buster wd 40 and BBs the BBs are steel and coated with copper.
    you can also do the anode thing with your battery charger and a mild steel rod google it
