Seca 750 battery light flashing: remedy?
Discussion in 'XJ Technical Chat' started by stv1991, Jan 4, 2017.
  1. stv1991
    stv1991 Member
    I put a new gel battery in my 1981 Seca 750. The battery warning light flashes on the dash until I cancel it. I thought I read somewhere on here that there is a kit or parts to purchase that will remedy this. If so, where can I purchase from?
    Thank you....
  2. Jetfixer
    what is flashing originally was the battery cell level sensor. Find the wire get a couple of if I recall .02 ohm resistors if you can find a Radio Shack , crimp 2 together , and crimp one end to wire and other to the positive terminal and now it will indicate like a crude volt "meter" if battery gets low should indicate on Atari anyway that is what I did.
  3. k-moe
    It's a 2.2 K ohm resistor rated at 1/2 watt, and you only need one. Add a bullet connector, a ring terminal, some wire for length, shrink wrap, and you're golden.
    Chacal sells a premade kit if you aren't handy with electrics.
    Jetfixer likes this.
  4. Jetfixer
    Yes kmoe is correct ... I could not recall ohm reading.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Where have I heard that before?
  6. k-moe
    Not around my house.
    Stumplifter likes this.
