Seca rear shock replacement
Discussion in 'XJ Technical Chat' started by Minimutly, Jun 4, 2018.
  1. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Anyone know the answer to this?
    Thanks in advance.
  2. Minimutly
    West Wales, uk
    So the question is, are 750 (seca or maxim, assuming they are the same length) a straight swap into the maxim, or are seca/maxim all the same length? What about the pin diameters?
  3. mr blackstock
    mr blackstock New Member
    Victoria, Australia
    A few years ago when I needed to replace my shocks, I just measured the distance "eye to eye", then went to a wrecker and picked up some very sweet Honda shocks that were almost new and matched the same measurements as my originals. Cost me $100.
    If you are a hardcore racer then spend big on shocks, tyres, fork springs, pistons, exhausts if you can pay it, but I ride to work and occasional hard rides so I focus on value not so much performance.
  4. Minimutly
    West Wales, uk
    Thanks mrblackstock, i just did a search, which I should have first off:
    https://www.xjbikes.com/forums/threads/maxim-rear-shock-compatibility.117926/
    Looks like they're all the same give or take a half inch or so, the 750 maxim could be stiffer sprung. I have a chance on a pair of used ikon adjustables, as usual the seller is not specific on what they were specced for, but the info in the link gave me the what I needed. Thanks for replying, the silence was deafening...
  5. hogfiddles
    I know the 750 Maxim regular shocks are the same as the 650 shocks and only have a heavier spring around them. The other 750 Maxim shocks look like air shock, and may be. The 750 Seca shocks have a different top. I don't know how they'd come apart. I haven't tried.
    But if you have compressor, you could swap your springs out for heavier springs......
    Minimutly likes this.
