Seca Windshield
Discussion in 'Hangout Lounge' started by Stteve0214, Oct 7, 2017.
  1. Stteve0214
    Stteve0214 New Member
    Ohio
    I have a 1983 Yamaha XJ 750 Seca with the factory body work. New purchase. The front fairing is the big one with the extra light. I need a new wind screen for that faring. Where can I find one?
    Start a conversation with Chacal.
  3. chacal
    We have them in stock!
    Front Fairing Windscreens and Headlight Covers:
    Aftermarket front fairing WINDSCREENS are made from an automotive-grade acrylic material, heat molded into the original shape, and pre-drilled to fit original fairings exactly. Available in both stock crystal clear or in an attractive dark smoke tinted version, these windscreens are the finest quality duplicates of the originals offered anywhere.
    1981-83 XJ750 Seca models:
    NOTE: 1984 XJ750RL Seca windscreens are listed with the XJ900 windscreens further below.
    See the threads linked below for the proper ID of your XJ750 Seca fairing:
    1981-83 XJ750 "Bikini" fork-mounted fairing:
    http://www.xjbikes.com/forums/threads/bikini-fairing-installation-mounting-hardware.43095/
    http://www.xjbikes.com/forums/threads/seca-750-sport-fairing-wind-screen-want-want-want.42040/
    1981-83 XJ750 Seca Touring Package frame-mounted fairing (see the images in the Ross1bd post):
    http://www.xjbikes.com/forums/threads/universal-lowers-aka-leg-guards.47881/#post-481555
    and
    http://www.xjbikes.com/forums/threads/front-fairing-swap.70718/#post-473424
    1984 XJ750RL and XJ900 frame-mounted fairings:
    http://www.xjbikes.com/forums/threads/front-fairing-swap.70718/ (see the picture in the post by k-moe)
    and
    http://www.xjbikes.com/forums/threads/xj750-rl-what-exactly-is-it.37640/
    HCP13558CLR Aftermarket original-replacement front fairing WINDSCREEN, clear, stock 14" height with small air-deflecting "windlip" at the top edge. For all 1981-82 XJ750 Seca models using the stock Yamaha "bikini" style fairing.
    HCP13558DT Aftermarket original-replacement front fairing WINDSCREEN, dark smoke tinted, stock 14" height with the small air-deflecting "windlip" at the top edge. For all 1981-82 XJ750 Seca models using the stock Yamaha "bikini" style fairing.
    HCP13559CLR Aftermarket original-replacement front fairing WINDSCREEN, clear, stock 17-1/2" height. For all 1982-83 XJ750 Seca models using the stock Yamaha mid-length fairing that came with the factory "Touring Package".
    HCP13559DT Aftermarket original-replacement front fairing WINDSCREEN, dark smoke tinted, stock 17-1/2" height. For all 1982-83 XJ750 Seca models using the stock Yamaha mid-length fairing that came with the factory "Touring Package".
    HCP16596 Aftermarket original-replacement front fairing HEADLIGHT COVER, crystal clear, curved plastic lense replaces the original curved glass lense perfectly. For all 1981-82 XJ750 Seca models using the stock Yamaha "bikini" style fairing and the 1982-83 XJ750 Seca model with the larger "touring package" fairing.
    Dadoseven likes this.
  4. Stteve0214
    Ohio
    Is there a phone # to place an order?
  5. Dadoseven
    Dadoseven Active Member
    Omaha
    Just start a conversation through this site. (Click on Chacal's avatar or username). He will get back to you. You won't be disappointed in the service and the part will fit. I plan on getting one of these windshields myself and have looked around, his pricing is as good as anybody's and the service is unmatched.
    Lightcs1776, kosel and Plug like this.
  6. Steve R
    Steve R Member
    Kansas
  7. Steve R
    Steve R Member
    Kansas
    Hi, I'm looking to replace my homemade windscreen on my 1983 Yamaha Seca xj750 sport fairing. Do you have a price? Clear without a flip would be fine. Thank you
  8. k-moe
    It's best to start a conversation directly.
    @chacal
  9. Steve R
    Steve R Member
    Kansas
    Thanks. I will.
