Sensor Issue
Discussion in 'XJ Technical Chat' started by BhamXJ550, Oct 19, 2018.
  1. BhamXJ550
    BhamXJ550 Member
    Bellingham
    swapped the bars on my ‘82 XJ550 Maxim and now the start button won’t turn the bike. I’ve been having to bump start it. I replaced the solenoid, tested all the power flow, double checked wiring and everything should work. I think the issue is the clutch sensor. The wire for it is really loose and I think it might have broke when re-arranging the wiring for the new bars. Is there a way to either make the sensor think the clutch is engaged or even a way to bypass that sensor?
  2. Franz
    You could possibly test it by putting a jumper wire between the terminals going to the clutch switch.
  3. Polock
    on some bikes the throttle side needs a ground to the bars. are your new bars painted/powder coated/anodized?
    you may need to scrape a little off
