shifting
Discussion in 'XJ Technical Chat' started by bossone60, May 30, 2011.
  1. bossone60
    bossone60 Member
    we are replacing the gasket on the shifter side and having problems getting the shifter to spring back. it will still shift one gear at a time but then will not shift again till you play with the shifter.
  2. RickCoMatic
    Make sure that the Shift Lever Rod Mechanism engages the Shifter Shaft Rotating Mechanism with the Middle Cogs lined-up together.
    Be sure that the Tensioner Spring, ... at the Top of the Ratcheting Shifter Air is:
    Present ... and, ...
    Connected.
    http://www.yamaha-motor.com/sport/parts/home.aspx
