Shim under bucket
Discussion in 'XJ DIY How-To Instructions' started by Donglord, Aug 6, 2025.
  1. Donglord
    Donglord Member
    Arkansas
    I've noticed the valve adjustment tutorial with pics in these forums for the air cooled versions of the maxim. Is there something similar for the shim under bucket water cooled versions? 1986 maxim 700x to be specific
  2. hogfiddles
    There WAS…… I’ll see if I can find it
  3. hogfiddles
    Franz and Timbox like this.
  4. Donglord
    Donglord Member
    Arkansas
  5. Donglord
    Donglord Member
    Arkansas
    Also is there a manual out there anywhere I can download?
  6. Timbox
    You should be able to do a search for both and find what you need. The shims are not cheap, so make sure you do the calculations and order the ones you need. The shims you have in the bike might be able to move around and get over valves in spec. This process will take a while and might have your X down for a bit. Take is slow and steady.
  7. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
  8. hogfiddles
    Order the from Len at xj4Ever.com
    Timbox likes this.
