Shock absorber swap.....
Discussion in 'XJ Technical Chat' started by chacal, Sep 19, 2006.
  1. chacal
    Will the turbo 650 seca (82) rear air shocks fits properly on a standard 650 Maxim (82) (i.e. shock body diameter/clearance/length)? What is the ride/handling difference between standard and air shocks? Has anyone done this before and have riding impressions?
  2. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    I took the air shocks off my turbo and put them on my Seca RJ and I have had no problems. Granted, a Seca is not a Maxim though. I had to do some fancy routing under the seat to avoid pinching the air hose but other than that, it was a direct swap.
    I'm a bigger person and wanted to dial in the suspension a bit more with the air option. Hope this helps. Good luck!
    Rob
  3. Robert
    I can swap the shocks between my 81 Seca and Max, expect you could do the same. Did it to hold the rear end up once, not to ride, sorry.
  4. Altus
    Altus Active Member
    London, Ontario
    Yup - you can - all the XJ's use the same rear shocks - 12.5" eye-to-eye.
    Note - you can also use some Hardley Driveableson shocks for heavier-duty replacements - you just need to change the bushings in the eyes to fit our Yamaha shock mount studs.
