Signal Fuse
Discussion in 'XJ Technical Chat' started by Robinwolfy, Nov 18, 2018.
  1. Robinwolfy
    Robinwolfy New Member
    Orlando, FL
    I have a 1980 XJ650 and the signal fuse keeps blowing. This prevents me from having a brake signal, horn and turn signals. I'm having difficulty tracking down why it keeps blowing even with all of the signals connected. I currently have the horn wires jumped since I do not currently have a horn. There's also a red and blue lead that don't seem to go to anything in headlamp assembly. they both have female ends of a bullet connector.
  2. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Soomewhere you have a short..
    When does the fuse blow, right signal, left, or brake light?
    That will help you find which circuit.
    Likley its where a signal wire passes thru the mount, shorting to the frame.
    Bad ground anywhere can cause similar issues.
    Hope this helps :)
  3. Robinwolfy
    Orlando, FL
    It shorts when I turn the key.
  4. XJ550H
    what do you mean by " I currently have the horn wires jumped since I do not currently have a horn."
    the pink wires to the horn are hot live voltage. when you press the horn button you are making a connection to ground.
    unplug the blinker canceling unit Flasher canceller: under the rear of gas tank, behind ignition coils. its about 3 inches long
    unplug your directionals check wire colors
    unplug the brake lights check wire colors
    reconnect 1 system at a time untill fuse blows
    signal fuse controls
    blinkers and pilot light
    brake lights
    Horn
    Neutral pilot light and switch
    in diagram R/W wire comes from key switch
  5. Robinwolfy
    Orlando, FL
    The brown and pink leads that connect to the horn are currently jumped. I did have it open before. Fuse still blew.
  6. Colin 85 700
    Thunder Bay, ON
    Undo those thats a dead short
  7. Robinwolfy
    Orlando, FL
    It still shorts without them jumped. That is it's current state, open.
  8. XJ550H
    the first thing to do is unhook all the components that are on the signal fuse
    blinkers in the head light bucket and at rear of bike disconnect and label the connections
    disconnect the flasher unit
    brake lights you can unplug front switch in bucket and the connector near foot pedelor unplug at rear of bike
    Horn unjump the wires
    if fuse still blows after disconnecting every thing you want to look for pinched wires.
    if not start reconnecting things 1 at a time
    start with flasher if fuse blows with flasher installed you may have a lose wire in the control
  9. Robinwolfy
    Orlando, FL
    If the neutral switch is on this circuit I wouldn't be suprised if that is where my problem is. The light is very dim ( only visible at night ) and only on when bike ISN'T in neutral. Bad switch blowing fuse?
  10. XJ550H
    yes the neutral light is on that fuse
    check out your diode block
  11. XJ550H
  12. Robinwolfy
    Orlando, FL
    Diode block replaced with brand new one.
    Wires cleaned up front and rear.
    Fuse still pops.
    When I get off work I'm going to see if my neutral pilot still lights.
  13. XJ550H
    check the connections for the signals the ground is not isolated it connects directly the mounting stay (metal rod
    holding the light fixture).
    one hot lead is green the other hot lead is dark brown
    the black grounds are a heaveier wire . could also be the hot leads are chafed where they go through the shaft
  14. XJ550H
    take the left control off of the handle bars
    look inside under the switch mechinism is 3 wires see if the brown/white wire is still soldered to the little brown pcboard it is hot and could have come free and is grounding to the control body through the bars. there is also a dark brown and green wire on the board.
    you could just disconnect the 2 connecters from main harness to isolate the control then see if fuse still blows. if it does the control is not the problem
  15. Rooster53
    That is a normal condition if the signal fuse is blown or missing and not supplying 12V to the signal circuit. The neutral light is being dimly illuminated by the 12V ignition from the starter cutoff relay to the neutral bulb and attempting to supply power to the signal circuit through the neutral bulb.
    This is good advice
  16. XJ550H
    have you unpluged the self canceler yet to eliminate it as problem?
  17. Robinwolfy
    Orlando, FL
    It was this unit.
    I thought I had checked it when I unplugged the other relays on the circuit, but here we are! Ok. So new canceling unit and should be all good. Few other things to clean up now, but most importantly, I have a functioning brake light.
    kosel and Rooster53 like this.
