Simmy's Naked Turbo Project
Discussion in 'XJ Modifications' started by Simmy, Feb 25, 2017.
  1. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    I think there are two kinds of manual boost controllers:
    1. Boost Controllers that bleed off air from the compressor before it gets to the wastegate. This means that some of your boost is always bleeding off to atmosphere. Setting these is counterintuitive, the lower the spring pressure the more boost you bleed off and the less pressure your waste gate sees (more boost). I think it's supposed to be smoother (i.e. the wastegate will eventually see the 7psi it requires to fully open), but it's a more gradual result. These are most common.
    2. Boost Controllers that work as a check valve, adding spring pressure to the compressor pressure. This will delay a signal getting to the wastegate until the compressor pressure exceeds the spring pressure. Increasing spring pressure increases boost. I made a bleed boost controller into one of these by plugging up the hole. There may be some "flutter" in the waste gate, as when you set say 12 psi on the spring pressure, the wastegate sees nothing at 11, then BAM 12 psi and swings open, dropping boost below 12psi. Then the ball valve shuts and the wastegate sees 0 psi, closing it again. However, in running it on my own turbo, it didn't seem like a problem, and I usually only boosted to 11psi for short bursts. Maybe there was no issue at all.
    Also a note on the powerup kit. It's just a delay valve that delays the signal to the wastegate. This means you can reach a higher peak compressor pressure (12psi) but the bike falls flat on it's face if you try to hold it there. When the wastegate gets the signal, it opens and drops the boost to 7 psi. I did not like that feeling and it didn't help the one dyno run I did.
  2. Simmy
    Thanks @k-moe I think at this point it might be just as easy to try another boost controller as they’re pretty cheap. Maybe this spring is too stiff.
    The 8 psi would be ideal for a 900, while I’m riding it as a 650 the higher boost is nice, they’ve certainly proven to survive this abuse.
  3. Simmy
    yes, below is straight from BoostValve's website:
    Camparison of a BoostValve and a bleeder valve
    The BoostValve prevents boost pressure from opening the turbo's waste gate until the desired preset boost level is reached. Inside the valve is a precision stainless steel ball that is held in place by spring tension. During the turbo's spool-up (as pressure is building) spring tension in the valve is greater than the boost pressure pushing against the ball, so the ball prevents the air from flowing to the waste-gate actuator.
    A bleeder valve is open all the time. Bleed valves work by fooling the waste gate into only seeing some of the boost pressure. The rest of the pressure is vented off, sometimes completely wasted by blowing out an open hose. Just like an air leak in any other hose this wasted air can cause problems with modern computerized engine controls. Additionally this causes the waste gate to open before maximum boost which can create turbo lag.
    Mine seems to be leaking at low pressure contrary to what BoostValve are claiming.
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Don't forget they are plumbed in differently. Most manufacturers went over to wired, electrically pulsed controllers years ago - you can buy them as kits.
  5. Simmy
    yes and below are the different schematics.
    The lower schematic is how I had mine installed.
    For such a simple device I have not yet figured out why it is restricting my waste gate from opening.
    I like those but at $400 a little pricey.
  6. ManBot13
    Fairfax, VA
    Simmy, did you try running the manual boost controller, in your current setup, with the dial screwed all the way in instead of out?
  7. Simmy
    No I did not. That would for sure just hold the wastegate closed.
    I think I know what you're getting at, which would make sense if it was plumbed in as per the bleeder set up.
    My BoostValve outlet is connected to the wastegate actuator.
    I've been conversing with the BoostValve manufacturer.
    They have different rate springs, its possible they sent me the stiff one.
  8. ManBot13
    Fairfax, VA
    Sorry, I didn't read your previous post closely enough as to which setup you used.
    I see you tested it and showed that it would let air by at 1psi, is there any chance that you plumbed it backwards on the bike?
    Where are you getting the boost signal from? The airbox nipple or the compressor? I remember a cap on the compressor port. Not sure if that makes a difference
  9. Simmy
    I’m coming directly from the compressor to the controller. I have Tee in this hose to the boost gauge but that won’t matter.
  10. Simmy
    Where the boost signal comes from might be the key thing here.
    This is what Ric Gillis from BoostValve just wrote me, he is suggesting the same thing you have;
    I usually like to set up the Boostvalve where there's negative pressure (vacuum) going to the inlet side of the valve so when you let off the throttle it snaps the Boostvalve shut. Turbos tend to keep spinning after you close the throttle delaying the response of the Boostvalve. I would cap off the port at the turbo. Tee into the boost sensor line and route that to the inlet of the Boostvalve. You might want to run your boost gauge off this port too. Keep in mind we really don't care how much pressure comes out of the turbo itself. What matters is what is at the intake, that's what is actually going into your engine.
    For anyone else still following along, here's a schematic of what Ric Gillis has suggested.
    Hopefully this is insightful for anyone else considering upping the boost pressure of their Turbo.
    I hope to get some time this weekend to make these changes and test it.
  11. ManBot13
    Fairfax, VA
    So my setup (not saying you should do it) left the "green" line stock (i.e. running the port on intake #2 just to the boost sensor for the dash gauge and TCI ), and plumbed a T off of the "red" line from the intake to the pressure regulator. But I was also more worried about the stock fuel pump not keeping up with the boost as I adjusted the manual boost controller, and the fuel system cares about the compressor output, not the manifold pressure.
    So I guess it all depends on what pressure you care about more. If the boost valve shuts with throttle, then the waste gate stays closed and the compressor will keep building pressure until the blow-off valve pops (I guess that's what it's there for, for the sudden closing of the throttle). I understood that in general, if you aren't using the boost pressure, (i.e. throttle closed) you want the wastegate to open to reduce the drive on the turbine side. Popping the blow-off valve means that the compressor isn't working against anything at can overspeed (and it already spins very fast as is).
    Manifold pressure drop due to the venturi and will also vary with throttle opening. So you can be building more pressure behind the throttle plates than you see at the intake manifold and your boost gauge. Furthermore, there's a bleed port on that boost controller, which may function as an air leak at times on intake #2 through the green line. The stock setup won't have a leak (as long as the line going to the sensor doesn't have any holes in it.
  12. Simmy
    I had this line dedicated to just the engine timing also thinking best not to disturb that signal with any T's.
    this line I've left alone as I did verify my FPR is functioning and my upgraded pump will always exceed any boost pressure the turbo is capable of producing.
    You're right the only time the BOV will pop open is when the butterflies are closed, and instantly removing an resistance to spinning may allow it to spin even faster.
    Combustion is reduced which will slow the turbine but I agree there will be a time lag for this.
    The hole on the controller is only to release pressure and ensure the wastegate is able to close. It should only leak when the wastegate is activated.
    It would be nice to have 3 pressure gauges, one for fuel, one for surge tank and one for manifold pressure.
    If I had a fairing I would consider it. Once I have control of my boost pressure and set to a reasonable limit I do intend to remove it entirely though.
    Hopefully I can just ride it and focus on the rapidly approaching horizon. Not there yet.
  13. Simmy
    On Friday I reconfigured the boost controller as per my diagram above, ie; tapping the #2 cylinder intake.
    I set the preload on the spring near the limit for lowest boost.
    Rolling the throttle on in 5th gear the boost went to about 12 psi and remained very controllable until I had to back off anyway.
    Once I got to a back road I took it to 6,000 rpm in 3rd gear and whacked it open.
    Same thing as before, the gauge spiked to >20 psi and popped the BOV valve open.
    I'm not sure what to try next.
    As I demonstrated before when I took the boost controller out of the circuit the bike ran perfectly with the OEM actuator controlling things.
    Boost would climb to 7-8 psi and hold, even when accelerating in lower gears.
  14. Simmy
    Rick at BoostValve is sending me a replacement unit to run at low pressure with a low pressure spring (0-20 psi) replacing the standard spring.
    I'll wait and see if this does it.
  15. tobar
    tobar Member
    england
    one of my favourite threads from any bike forum..looking forward to updates...i cant help thinking that the xj6 front end would be a perfect match for the rear wheel?
    chris123 likes this.
  16. Simmy
    I bought a turbo parts bike.
    The motor looks good but it might be seized.
    If the bottom end looks good I’d like to fit my 900 cylinders to it. This makes a 738.
    The 900 crank and cases I have can be another motor later.
    Loki is sniffing the intake for mice, LOL
  17. Simmy
    Awesome oil cooler for someone's project. If anyone needs anything just PM me.
    Turbo, carbs, body work are all gone.
  18. Simmy
    I’m currently running the bike without the boost controller. I have the pressure tap on the compressor plugged off and take the pressure signal from the nipple on #2 carb. No.2 is the only carb with this nipple.
    From there it goes directly to the turbo actuator and opens the wastegate.
    It builds a solid 9psi but most importantly holds that pressure when I accelerate through the gears. I can ride faster because it’s all so controllable.
    When I had 16 psi it still quickly hit that in the lower gears.
    When it popped the wastegate the stock actuator was overwhelmed, all this is happening just when you’re looking for the next gear.
    I’m just now pulling the boost gauge and putting the other mirror on.
    At 9psi it’s still a wicked fast ride, and totally illegal when ever on boost anyway.
    sybe, k-moe and Dave in Ireland like this.
  19. Simmy
    Oh and also repositioning the Yamaha badges on the tank. I had them level with the ground and it didn’t look right. Finally got up the nerve to remove them from that beautiful paint. WD40 helped.
    And I still have a pulse from the front brake.
    I had these discs powder coated and they look awesome, I’ve not wanted to make the realization that one might be warped.
    I’ve seen some Brembo floaters listed for a Virago, maybe time for that splurge.
  20. Simmy
    Commuted to work today on the Turbo.
    I repositioned the Yamaha badges, removed the boost gauge and mounted the LH mirror. I got everything the way I want for now.
    The winter project will be building a bigger motor for it.
  21. Bobby Boogie
    Bobby Boogie New Member
    Kitchener
    Looks really nice, like the colour.
  22. nedc
    nedc New Member
    Manning, SC
    I had to LOL at your comment "I got everything the way I want it for now"... just got to build a bigger motor. The need to tinker/improve never goes away does it? Love the bike, Seca 650 is one of the favorite bikes that I have owned and yours is a stunning example.
  23. Simmy
    Thanks for the comments guys, much appreciated.
    It's hard to believe I started this project 5 years ago.
  24. sybe
    sybe Active Member
    NYC - Brooklyn
    5 years of great entertainment and inspiration. This build has always impressed me and I tip my hat and blip my throttle to you!
    Simmy, lostboy and Rooster53 like this.
  25. Simmy
    I’m at the Toronto Motorcycle Show with my Seca. I set up early and got 1st spot on the red carpet.
    They get 50,000 people through here this weekend. 5 massive hall’s of motorcycles.
    $10 to enter a bike and you get a free weekend pass. Big prizes too. Wish me luck!
  26. BallAquatics
    BallAquatics Active Member
    Ohio, USA
    Good luck Simmy, nice looking bike!
  27. hogfiddles
    Get a trophy, man!! I’ve gotten plenty for my 900rk, hope to start getting a few for my 650rj’s soon, too:)
    fingers crossed for ya !!
    dfox
  28. Dan Gardner
    Minneapolis, MN
    Good luck @Simmy !! Such a cool project.
  29. chacal
    If you don't win that means the fix is in...........
  30. Fuller56
    Fuller56 Well-Known Member
    I agree with Len. That is one spectacular motorcycle.
  31. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Make us proud.
  32. Simmy
    Well I got a "thanks for coming out" award.
    The vintage category was won with an original Suzuki Katana, it was gorgeous.
    I returned to the show Friday and saw they had moved my bike in line with some others.
    The plaque I had explaining my bike was kicked under the bike so no one saw it for anything but a shiny green Seca.
    I should have made a stand for my plaque, it was too small and no one read it.
    I have won awards for my Seca-X sidecar.
    Kitchener-Waterloo used to have a weekly bike night at a popular bar, I rode it there just once.
    They judged all summer and I won 2nd place in radical custom which I thought was awesome as there were many $100k+ Harleys there.
    I suppose my Turbo is just too sedate to stand out, but that was my intent after all.
  33. Dan Gardner
    Minneapolis, MN
    That's kind of a bummer, @Simmy. I guess some of the coolness factor is lost on those without some knowledge of the Yamahas of the era.
    At any rate, it doesn't matter. It's still super cool.
    You get a trophy from me!!
    lostboy, chacal and Simmy like this.
  34. Fuller56
    The vintage guys were threatened by your awesome work so they hid your descriptive plaque. The fact that your bike is rider not a display queen is just all that more threatening to them.
    Dave in Ireland and hogfiddles like this.
  35. hogfiddles
    I’ll “share” one of mine with ya
  36. hogfiddles
    Which one do you want to pretend is yours? I’ll take a pic of it for you......
    Franz likes this.
  37. Simmy
    Mighty kind of you @hogfiddles
    Not so much the trophy, I wanted cash.
    I think only the custom Harley class got that.
  38. hogfiddles
    Cash prizes?? Nice... they don’t do that around here
  39. chacal
    Hey Simmy, I'm going to make things right for those jokers (told you the fix was in.....). I hereby am appointing myself extraordinary judge of the Toronto Motorcycle Show and awarding you a $100.00 Gift Certificate as the 1st Place Award Winner in your class.
    Dave can send you a trophy.
    We take care of our own around here...........
  40. Simmy
    Wow, you sure do!
    Thank you very much.
  41. hogfiddles
    You are also invited to attend the CNYCC#16 In June.
    we’ll line up ALL the 650rj’s for a group photo!
  42. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I thought you said #16 was all about 700X's.
  43. hogfiddles
    I didn’t say it’s about any one model in particular.....
    if there’s a bunch of X’s, we can line them up, too :)
  44. Simmy
    My sidecar is an RJ with an X motor so would fit in the middle of a picture like that.
    If you continue to host these I would sure like to make it out one day.
    Your timing @hogfiddles is always the same weekend as our big vintage rally in Ontario, one day then.
    Simmy's Naked Turbo Project continues;
    Today I pulled the motor from the turbo parts bike I bought last year.
    I started on this last weekend but left it for a week because one motor mount was completely frozen.
    I started drilling it out today, then asked myself why am I F'ing around.
    No one is ever going to build a bike from this frame so I just chopped it up to get the motor out.
    I still have a corner of the frame to remove, at least now I can turn the motor upside down and keep grinding away.
    I'm hoping this motor has a good bottom end, the gears all work anyway.
    I have an 83 Seca 900 cylinder block & pistons but I also ordered a block and pistons from Luxembourg from an 88 XJ900
    they should be here any day.
    Using the 68.5mm bore with the Turbo stroke will make a 772.
    The 67mm bore from the 83 900 makes a 738.
    A 772 with 9 lbs boost should be really fast, it should bring the boost on sooner to.
    If all I have to do is buy some top end gaskets, maybe some machining on the block to get the CR correct (8.2:1), then I can build a hot rod motor pretty cheap.
    When I have this motor ready it's a weekend job to swap in the 772 and put my original 653T in storage.
    One of the main bolts in the front is completely seized. The nut is off, the head is ground off and I pounded on with heat and no go.
    WARNING!!!! Not for the squeamish, sorry XJ fans, another Turbo has left us, not much left on this carcass.
    notice the 900 cases (in the middle). They have less material between the cylinders.
    All the 650s and 750s have round holes, I think the 700N also.
    The 900, 700/750X casings have the thinner ligament between cylinders.
    Dave in Ireland and chacal like this.
  45. Simmy
    My big bore kit arrived from Germany last week, finally got around to unpacking it.
    Initial inspection looks great, the bores have no visible imperfections.
    At first I didn't see any broken fins but there is a chunk missing below (above in the pic) the cam chain tensioner.
    Can't see it making much difference and it won't be visible.
    here's a pic of the OEM turbo piston - 63 mm versus the 68.5 mm piston from the Euro 891cc motor.
    The turbo came with forged pistons. I'm controlling boost with the OEM actuator which limits the motor to about 9 psi by my observations.
    I'm confident these cast pistons will survive the heat. Combining them with the 650 crank makes a 772.
    I need help from someone who has the Yamaha service manual for the 891 .
    I've copied the pages from my 83 XJ900 RK manual with the 853 motor.
    Need to see if the piston clearance and ring gap is different.
    I should probably compare the 650turbo to the standard 650 also to see if a turbo needs looser tolerances.
    Dave in Ireland likes this.
  46. Minimutly
    West Wales, uk
    Hmm, couple of questions.
    Are you sure the bore (and rods) clentrelines are the same for the 650 and 900 bottom ends? Ie have they widened the spacing to get everything in?
    Secondly, why didn’t you keep the thing 900 cc? Just use the turbo scavenge pump etc? Sorry if I missed that further up..
  47. Simmy
    bore centres for XJ650-900 and 85-88 FZ700-1000 are all the same.
    I dissected my 900 motor and discovered some gouges in the main bearings, so that was going to require some new bearing shells.
    Likely contaminates in the oil caused this.
    I also discovered the Turbo has connecting rods with additional drillings and unique bearing shells to flow more oil.
    Oil travels through the centre of the crank and feeds each of the connecting rods. You can see below the Turbo has big reliefs
    in the bearing shells for a huge increase in oil flow.
    I have a Turbo motor I hope will not need much in the bottom end.
    I will need to inspect the usual weak points - ie; chain tensioner disintegration etc.
    I can build a 772 cheaper than rebuilding my 900 motor.
    And a 900 motor would never get the proper oil flow for turbocharging.
    I thought about drilling the 900 rods but Chacal says the Turbo's bearing shells needed are no longer available anyway.
  48. Minimutly
    West Wales, uk
    Oil cooling for the underside of the pistons...
    Good that the centrelines are all the same though, makes life easier. Well done with this so far!
  49. Simmy
    you are correct, the hole in the con rod is to direct oil to the underside of the piston to help dissipate heat.
  50. Dave in Ireland
    Ireland
    I can send you the info from Haynes manual for the Euro engine, if you like.
    Or can upload it and you download it from mediafire.
