SIMPLE MOD MAY SOLVE POD TUNING HARDSHIPS!
Discussion in 'XJ Modifications' started by RickCoMatic, Jan 11, 2012.
  1. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    Hey guy been a long time since i have been on had surgery havent been riding. I have been playing around with the pods and have figured a few more things out. The kidney hole can't be restricted in anyway it need the air valosity in order for everything to run correct. it needs that pos pressure in order for the functin right. I have make insert and everything but restricting the hole any effect the way the bike will run when you use the inrichment when warm up. the bike iwll not pick up engine speed. what i have done is the following. i used the boots off of the air box. they fit my pod perfectly. The grove that was used to hold them to the box is the grove that my pods attach to and then they just attach to the carba normaly. there is a slight clearance problem with the outside pods but i can live with that. that is what i have come up with. Im in the mix of rebiulding all my carbs alot of smal problems... (throttle shaft seals were shoot) once i get all the parts i will get back to working on this problem.
  2. 750E-II_29Rbloke
    South Cheshire, UK
    So, really what's basically happened after all this time & effort is, that we discovered that the simplest, cheapest & quickest method to eliminate/minimise the effects of POD induced turbulence affecting the slide-lift/air jet's air supply, is to utilise Yamaha's original velocity-stack airbox rubbers.... Kinda a bit like Streetbrawler originally did way back when? :?
    And this still doesn't account for the fact that POD's improved PEAK mass airflow over the stock airbox would still require a larger main jet to provide stoichiometric mixture at WOT heading to peak revs....
    *runs away swiftly after booting hornets nest* :twisted:
    #please note before your flame attack, the author does not detract from anybody's ideas/theories or testing whatsoever & in fact humbly admires the hours of thought, research & effort put into attempting to find solutions for those who insist on running pod filters for whatever reason that may be, but is merely stating the facts as they are at this moment in time, that if you fit pods, "you're gonna need to rejet"# :wink:
  3. southpaw
    southpaw Member
    new york
    Funny I posted that i had done the pod to boot set up after a deep conversation on the phone with rick back in 2008 No response I just thought everyone thought i was crazy. I will say it again Pods, High flow slip-on mufflers #126 mains #43 pilots shimmed needle .050 Pods attached to factory boots. 10,000 miles later still put a huge grin on my face when i get on that little blue rocket. Enjoy the ride people it doesnt last forever
  4. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Whomever is acredited with being the first to attatch the stock boot to the pod matters not, what matters is that it is above all the best solution to date.
  5. RickCoMatic
    I think a set of the Racing Velocity Stacks would help Narrow and Accelerate the Intake Stream helping the alleviate the Lean Condition.
    But at $600 -to- a Grand, ... you might as well pop for the Fully Adjustable Keihin Carbs or a set of Carbs off from a Kawasaki Police Bike.
    No matter which way you go, ... the price is going to way-up there!
    http://www.carbparts.com/keihin.html
    The Keihin Carbs are going for Multi-thousands of Dollars on Ebay.
    http://www.ebay.com/sch/i.html?_from=R4 ... rbs&_sop=3
  6. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    oh my god! why are those so much? whats so special about those carbs?
  7. quebecois59
    And then why would I buy carbs that expensive if I could simply use stock carbs, with stock boots and pods, with some specific new jets, all of this pretty cheap, like southpaw suggests?
  8. hogfiddles
    And to think I'm happy with connecting a stock airbox to the stock airboots and connecting them to the stock carbs with the stock jets. If I want a faster bike, I hop on one of the others. If I want more powerful ride, I just hop on one of the others.
    Yup.....as I've said before- I have a set of pods, too.....they sit right on the shelf, purty as can be. All brand new and stuff, right in their brand new boxes.
    Dave Fox
  9. RickCoMatic
    They're primarily, ... Racing Carbs.
    The faster you want to go, ... the more it's going to cost you!
  10. 750E-II_29Rbloke
    South Cheshire, UK
    You must be mad! Why on earth would you do that when you could have hours of fun diagnosing "ignition problems" that turn out to be fuelling glitches caused by those shiny new pods? :D :p
    For the sort of money those carbs make you could go faster on another bike than any XJ is ever going to do with those carbs fitted (cheaper to go 190mph on a stock old 'busa than it'd be to fit them to an XJ and do all the other mods to reach that sort of speed.
    I wonder when people will stop trying to make a race bike out of a 30+ year old shaftie? Maybe we should drill our cranks next :roll: :lol:
  11. Skipnick
    Skipnick New Member
    Hudson valley
    So the stock rubber joints would reduce the wind tunnel effect?
    Just a thought seeing as I have read many of the pages but Not all damn 21 ,
    Has the thought of a baffle inside the pod been brought up?
    Just like a 1" thick "X" or something made of tin to break the wind tunnel up? Or am I not understanding the tunnel concept correctly.
    Just a thought!
    I bought my xj700 with pods , bike runs stupid rich, im working on it.
  12. RickCoMatic
    It's not a "Wind Tunnel effect, per se.
    The Boot acts as a Velocity Stack.
    The Boot has a narrower Inside Diameter.
    The AIR drawn through the Boot takes shape.
    It becomes a column of dense, Un-turbulent, air; accelerated to perform a vital function.
    Reducing the PRESSURE at the Top of the MAIN NOZZLE (Emulsion Tube).
    With a Low Pressure at the Nozzle's Exit Orifice; MAIN FUEL JET supplied FUEL is Siphoned into the Air Column.
    Additional AIR from the drilled orifices surrounding the NOZZLE contribute greatly in Siphoning the FUEL.
    Without the Boot, INTAKE AIR Supply is much more Turbulent.
    The AIR is less compact.
    The Volume lacks speed and shape.
    LESS PRESSURE reduction at the NOZZLE Exit weakens the Siphoning action.
    The Bike runs Lean.
    Various Jet Kits are available offering to alleviate performance related issues.
    Search "PODS" in the Forums.
    We should have initiated a Hall of Fame for the various designs, many with photographs, that Members developed searching Intake nirvana.
  13. bigfitz52
    If it's running rich, your carbs have likely been "modded" either by rejetting or somebody may have drilled the jets.
  14. Skipnick
    Skipnick New Member
    Hudson valley
    Agreed. When I crack them open I'll be sure to go the extra mile and write down jet sizes and inspect them for drilling. I definitely smell a bit of gas in the oil. Lots of factors to rule out still. My enrichment stalls the bike.
    Lots to do, little time to do it .
  15. dernst
    dernst New Member
    In two weeks I'll be back stateside to greet a cosmetically challenged Seca with a clean power plant but the rest of her needs some serious love and some new gasketry... I decided to get pods.
    May God help me. 8O
  16. camma
    camma New Member
    York western australia
    Hi there guys, can anyone tell me if the gears in a XJ 650 are the same as an xJ750
    Thanks in advance
  17. camma
    camma New Member
    sorry I posted into the wrong place, will get the hang of this one day
  18. remo
    remo Member
    Northern New Mexico,usa
    ya i like my keihins, stock boots, green foam and mens dress socks,black hair ties under $5. go ahead and call it ghetto, seems to be working great. However I am modifying a kz stock air box with an automotive air filter cut to size. with mold rubber and masking tape over. the rubber pours around the edge, allowed to set then peeled the tape up. somewhat replaceable. still looks like crap, bondo and paint. my socks just go right in the laundry.
  19. MiGhost
    MiGhost Well-Known Member
    After 18 months +/-
    And 22 pages
    This is what all the discussion produces.
    So with this being the only testing done.
    Can we conclude that the original theory was incorrect, and that by far the simplest way to adapt the bike for the use of pods is to use the original airbox to carb boots to correctly shape, and deliver the correct airflow into the carbs?
    Velocity stacked pods (stock airbox to carb boots).
    Rejetting Required!!
    Ghost
  20. Andyam5
    Andyam5 Member
    Luton, UK
    Anybody know of a simple alternative to the airbox rubbers? Will a length of hose do the job? Will stacks from a different bike fit?
    The PO of my Seca proudly told me how he'd fitted new pods before putting the bike up for sale, the box & rubbers are long gone and spares are non-existant here in the UK
    I'm loving bringing this one back from the dead and I want to get it as good as I can
  21. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    How did I post on this thread?
  22. Andyam5
    Andyam5 Member
    Luton, UK
    Guess that'll be a no then :(
  23. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Andyam5 - the airbox rubbers aren't quite "hose".... they have a bit of a contour and shaping on the inside to form the air.
    I replaced my long gone ones with airbox to carb boots from a 4 wheeler that were pretty darn near close in size.
    Ask any GOOD bike shop about needing suitable replacements, and see what they have. they would really just have to be the appropriate diameter to fit on the carb
    Also, there is a thread on here somewhere (search for it) about a rubber PLUMBING connector that works and is dirt cheap.... haven't tried those, but it's certainly an option too....
  24. Orange-n-Black
    Memphis Area
    Anything that is the diameter of the old airboots and smooth on the inside like the original airboots will work, along with the proper jetting and cursing of coarse. LOL
  25. Andyam5
    Andyam5 Member
    Luton, UK
    Thanks fellas, I'll see what I can find
  26. MiGhost
    If you are using them to run with the pods. The airbox boots for the 650's are still available from yamaha.
    4H7-14453-00-00 JOINT,AIR CLNR 1
    1980 XJ650G INTAKE
    1981 XJ650H INTAKE
    1981 XJ650LH INTAKE
    1982 XJ650J INTAKE
    1982 XJ650RJ INTAKE
    1983 XJ650K INTAKE
    Ghost
  27. AlanMc
    AlanMc New Member
    douglasville
    do you keep the jets the same size when going from air box to pod filter. I am haveing an issue with mine.
  28. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
  29. MarkV
    MarkV Member
    Vermont
    anyone with pod issues, search for this in the forums," rejetting and pod air filter questions." I went by this chart, and it was a great starting point, I changed my main jets twice. After just over 2k miles on it, plugs still looking good. I used 2 stock boots, #2 & 3, and 2 fernco connectors from home depot for #1 & 4.
  30. Andyam6
    Andyam6 Member
    UK, Beds
    Woooooooooooohooooooooo :D
    I've found the ultimate solution to the "POD" problem
    1 Get on ebay
    2 Buy a used airbox
    3 Buy a new filter
    4 Fit airbox to your motorcycle
    5 Tear your pods assunder
    6 Listen to you bike idle like a sleepy p****cat :D
  31. paul.hardy
    paul.hardy Member
    Tasmaina - Australia
    Make one of these 50mm or 2inch PVC pipe and some plastic glue
  32. tom66
    tom66 New Member
    pa
    Plumbing fernco's from any home depo or lowe's work they are 1 1/2 to 1 1/4 inches the pods fit over the 1 1/4 end.this is what I am running on my bike 85 xj 700n jets are 116 mains and 41 pilots bike runs like a champ.
  33. tom66
    tom66 New Member
    pa
  34. RickCoMatic
    That arrangement looks more than vaguely familiar.
    That is, ... (in its basic form) ... the same configuration as an Airbox with a Filter.
    A single Air Filter supplying a "Shared Volume" Plenum feeding the combined Intakes of the 4-Pack!!!
  35. althomas101
    althomas101 Member
    Baltimore, Md
    After reading about half of the pages in this thread I'm left wondering a few thing.
    1. If you think the slide is lifting slower then why not just either drill the slide or install softer springs?
    2. If the emulsion tube isn't atomizing fuel well enough due to reduced pressure in the "kidney" then why not install a larger air jet?
    It seems to me a velocity stack would do 2 thing; straighten the air flow, and reduce pressure even further before the "kidney". Air reduces pressure when it speeds up.
  36. paul.hardy
    paul.hardy Member
    Yes your right Rick. Just like the standard air box. So the moral is don't cut up or throw away you air box or you will have to make something like this when you are sick of stuffing around trying to get the bike to run right with PODS. I learnt the hard way. Having said this however, its very simple and easy to service the air filter or get the carbs off the bike when need be, with this setup. For those guys that do Bobbers and Café racers you could easily make one of these with 3 blank pods to get that Pod look and have the bike run to is optimum. like the air box system is designed to do .
  37. RickCoMatic
    We should therefore conclude that without being separately isolated from its adjoining carb ( 1 ) - (2) (3) - (4) ... the side-by-side, oscillations the (1)~(4) & (2)~(3) Firing Order, causes severe Turbulence at the Intake Horns.
    This Turbulence, which increases exponentially as rpm's rise into the thousands, destroys the requisite SHAPE and SPEED of the AIR entering the Intake Horns.
    Each carb then GULPS what AIR is present at the Horn.
    Allowed to draw only from a worsening turbulent source; the Plant GULPS from this Air Supply.
    There is not enough Shape and Speed to let the Carb function as it should.
    There is no Accelerated COLUMN of Air speeding across the Nozzle (E-Tube) Opening, ... resulting in inadequate PRESSURE REDUCTION above the Nozzle lessening the Siphoning Effect needed to draw-up Fuel from the Main Jets.
    Now, ... its LEAN.
    Re-jetting is offered as a solution.
    But, ... INCREASING the Jet Size only serves to make more Fuel "Available" ... to ... NOT get Siphoned and Atomized out from the Nozzles Openings.
    I also theorize that the resulting turbulence also contributes to:
    • Insufficient Lowering of Pressure at the small opening at the bottom of the Diaphragm Piston, ... failing to make the Piston rise as rapidly as needed.
    Lean, again.
    • I believe that the Volume of Air drawn-in during the Intake Stroke, if the carbs are not isolated from each other, causes a decreased pressure at the Kidney Shaped Atmosphere Vent.
    I believe that without positive pressure at the Kidney Vent there is not enough Air present at that causing further complicating issues.
    • Air NEEDED to surround the Diaphragm, allowing the Diaphragm to collapse, is woefully insufficient ... hindering the rise of the Piston.
    • Less Air there also reduces the amount needed by the Main AIR Jets from which supply Air to the Nozzles. Hindering Siphoning and Atomization.
    Increasing the AIR JET Size might not solve anything.
    The AIR JET passages are only capable of a finite flow.
    This is what I theorize.
    It's my 2-Cents worth.
    Here's a Nickel.
    Keep the change.
  38. paul.hardy
    paul.hardy Member
    In my experience with POD you can get the bike to run good some of the time but not all of the time. I tried extending the stacks etc. but what I found was in cross winds, tail winds or even strong head winds it would momentarily drop revs or bog down and regardless of how much throttle you gave it it would not go any harder. I figure that these carbs, as well as some of the other stuff Rick mentions, need an equal air pressure out side the intake across all the ventures or air intakes that's why these bikes come standard with air boxes. With out the air box to stabilize the air pressure air flowing around the individual intakes with PODS can be at different air pressure due to turbulence from the bike just moving through the air.
  39. althomas101
    althomas101 Member
    Baltimore, Md
    I used to do a lot of street racing Mopars back in my 20's and I used to love it when a Camaro or mustang would show up with a tunnel ram and dual quads or a single 750 on a small block. Bigger isn't necessarily better, and most people don't know that. An engine is a system as someone already stated. The key is to match all of the components so that they support each other. This means that you need to match the carb size to supply maximum CFM flow but no more. That your intake runners are the correct length for the RPM range that the engine will see, likewise the head port size, valve sizes, camshaft profile, exhaust collector length, pipe length, and muffler flow all have to match the engines displacement, desired optimized RPM. This all of course needs to be optimized for the weight of the vehicle, and it's gearing.
    All things are trade offs, if you tune for peak power at high RPM then you will suffer with low RPM throttle response. That is what is happening with the pods. Engine vacuum is what give low throttle response, as it causes the carburetor to draw, and atomize the fuel. That is why on a slide carb bike, or manual secondary car carb, you get a “cough” if you open the throttle too fast. All vacuum goes away and the engine stops drawing fuel, hence why cars use accelerator pumps. What the CV in CV carbs does is maintain vacuum by only opening the slide just enough to keep the engine vacuum in the proper range for best carburetor function. It is exactly the same principal as a vacuum secondary car carb, which BTW you tune by replacing the springs on the vacuum pot.
    Going back to what I know best; a Mopar 340CI small block. That motor can only flow about 600 CFM at 6500 RPM with a VE of 95%. So I ran a carter 600 on it, a larger carb would have killed low end performance. (I swapped in a 750 one time to prove this to a buddy). The stock x head already has port sizes, and valves that can flow that much air so no head work is required other than smooting the port walls and port matichg the intake (to reduce turbulence). A plain old Edelbrock performer intake also is correct for the flow and RPM range, and is a dual plane to reduce plenum, which improves low throttle response (manifold plenums only help high RPM, plenums outside the carb throat do nothing). For cams I ran 282 duration, 484 lift, 108 centerline cam retarded 3 degrees to lower the powerband. That cam actually was even a bit of overkill as it would easily pull strong past 7K. I also used a small primary long collector header and “normal” exhaust pipe with a flowmaster muffler. The car ran 12.6 with all interior, skinny tires, and a stock 3.23 rear with an 11” stall converter, if I had changed the gearing to a 3.73 I’m sure it would have come close to high 11’s. Not bad for a heavy, daily driver.
    A 650CC motor can only flow roughly 90 CFM at 9000 RPM assuming an 85% volumetric efficiency which is probably optimistic on these old air cooled engines (a shop vac can pull this BTW). Four 32mm carbs can flow far more than what the engine can actually use, by removing the restriction on the intake (airbox and velocity stacks) your changing the design parameters and the expected range of the CV carbs calibration, and the engine looses vacuum, and yes you get external turbulence from the air stream. That is why it is common to put a shroud around the outboard pods.
    I think you actually need to put in stronger springs to slow down the slide operation to restore the vacuum to proper levels.
    You will always have to rejet to account for the increased air flow. And as I have found that all bikes benefit from at least one size larger main jet. Old bikes were designed for “real” gas, and ethanol requires a different AF ratio than gasoline, on newer bikes it is the EPA that made manufactures set them lean.
    The air jet IS the restriction on that circuit NOT the carburetor passages. In order for the passages to be the restriction you would have to remove the air jet entirely.
    Here is a good article discussing alot of this.
    http://www.carcraft.com/techarticles/se ... ight_carb/
    In summary, if you run pods and Shorty exhaust you are trading low end response for horsepower on the top end. You will never be able to “tune” back that lost response. So either don’t go to pods, or just learn to like riding a rev happy bike.
    hogfiddles likes this.
  40. jmilliken
    Dillsburg, PA
    interesting read althomas. thanks for sharing!
  41. althomas101
    althomas101 Member
    Baltimore, Md
    No problem, that is what forums are for. But don't take what I say as truth, research it for yourself, it is interesting stuff with real world application. When I was building my Dart, I read at least a dozen books on engine building because I wanted to do it right.
  42. tom.mcmullen
    tom.mcmullen New Member
    Yelm washington
    This is the only thing I understood
  43. eurosnap53
    eurosnap53 Member
    This is weird...re-jetting isn't a big deal when you have pods or velocity stacks. It's only a pain in the ass when you have the tight confines of an air box, which then, there really isn't a need to go crazy on re-jetting (all the work has been done by the factory, just apply sea-level formula). Props for the MS paint rendering and what about blocking off the inside of the pods (baffle or sectional)? Again, black magic, but if you must run pods then happy trails. I'm running pods BTW but still have my air box for safe keeping :)
