Slightly altered 83 XJ750 Maxim
Discussion in 'XJ Modifications' started by PavelK313, Jan 29, 2019.
  1. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Have a question for someone that knows more about XJs than I do.
    I just checked logs from today’s ride and it shows my max RPM were 12,873?
    Is this even possible?
    Tach seems to function fine and RPM matches speed at least when I look at it. But such high RPM kind of throws me off. I didn’t even know these engines could spin that fast.
  2. Polock
    PavelK313 likes this.
  3. PavelK313
    Fairfield CA
    FCBD17BB-266F-45F5-B8E9-024CB199972F.jpeg Received new gas cap today, but I didn’t want to use two keys (1 for ignition & one for gas) so I ended up taking parts out of new cap and swapped them over to my original cap. New seal, new springs, new locking mechanism. Greased everything inside and it seems to operate very smooth. Will have to do some testing to see if this fixed my problem with spilling fuel, but so far after tipping bike to the side until foot pegs touch the ground there are no leaks.
    Chitwood likes this.
  4. PavelK313
    Fairfield CA
    I cave in and ordered new rear wheel and new tire. Should be here in a week or so.
  5. PavelK313
    Fairfield CA
    Rust-oleum played a joke on me today....
    I decided to paint back side of my frame to prevent it from rusting until frame goes in for powdercoating later this year. Stripped the bike, masked everything off, degreased the frame and started spraying, everything went smooth, no runs, no dust. Waited around 8 hours for paint to harden and then slowly started putting bike together. The way I modified my bike, parts have to go back in exact order, otherwise nothing can be fitted since “tolerances” are quite tight. Once I was half way done, I mounted rear wheel & brakes and said WTF out loud! At that point sun started making its way into garage and I realized that what was supposed to be BLACK paint, was actually the darkest GREEN I ever seen!
    Let’s just say I was beyond pissed!
    Stripped bike back down, masked it all off again, degreased it once again and proceeded to paint with different satin black paint.
    Now it came out exactly how I wanted it. Left it as is and will be putting it back together tomorrow.
    I’ll include a few pictures.
  6. PavelK313
    Fairfield CA
    C0EEE545-E14F-4A00-9DA3-D0E20D75A3E1.jpeg FF83F20E-8B26-443A-A17D-CDF6ED87087A.jpeg Spent last couple of days working on my XJ. Back half of the frame & rear brake plate received paint (temporary until it all goes into powdercoating) and did paint correction on the gas tank.
    New rear wheel and tire should be coming in sometime next week.
  7. k-moe
    The few race bikes that were built ran the redline at 12k.
    The rules about what's safe change a bit when prestige is on the line instead of warranty claims.
  8. PavelK313
    Fairfield CA
    Went on the longest ride so far, 155 miles. Bikes performed well, but today was first hot day riding and I will be going up in jet size. Bike runs a bit lean.
    Besides that, I also rode through a full tank of fuel and was able to put 140 miles on it before having to switch to reserve, good range imo considering that tank is a lot smaller than stock. Also, achieved a milestone of 500 miles on the bike in its current form.
  9. XJ550H
    that's a seca 550 tank correct?
    4.2 gal total 0.9 reserve
    so about 42 mpg not bad.
  10. PavelK313
    Fairfield CA
    Correct on the tank model. My tank sits at slightly different angle than it does on XJ550. So I willed up I think around 3.7-3.8 gallons. Calculated 38MPG.
  11. XJ550H
    and I'm thinking you do not ride conservatively :)
  12. PavelK313
    Fairfield CA
    Lol
    Not at all! That’s another reason i sold 1000CC sport bike and bought old XJ. It’s plenty of fun to ride and keep it at somewhat reasonable speed. I am not responsible enough to own fast bikes. Haha
  13. PavelK313
    Fairfield CA
    Received new rear wheel and tire today. Will be dismounting old tire that new wheel came with and painting new wheel tomorrow.
  14. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    Love the look of your bike so far. The rattle can green is the same colour as an IKEA couch I have and my son swears up and down it's black.
  15. PavelK313
    Fairfield CA
    0CB0CC53-B16E-4D7D-A917-5731228B5F93.jpeg View attachment 35132 New rear wheel and tire mounted. Didn’t make as much of a difference as I expected but still an improvement.
  16. Uxbridge Brule
    Uxbridge Ont
    Ties the front and rear togeather nice looks like it was ment to be.
  17. PavelK313
    Fairfield CA
    Swapped in new jets yesterday since I felt like it was a hair too lean and went for a ride today. Well, I think I went too rich as for the first time in it’s life bike started bogging on low throttle. Needless to say, I will be going back to what I previously had.
  18. PavelK313
    Fairfield CA
    Update.
    Spent most of Saturday messing with carbs, swapped Jett’s, synced them and now bike performs flawlessly! Super steady idle at 1k rpm, zero bogging, great throttle response, no popping on deceleration, drops down to idle from redline instantly, exhaust sounds smooth and deeper.
    Also, this morning went to Sears point raceway to get my suspension adjusted and fine tuned. What a difference that made! Bike is very smooth on imperfect roads, absorbs impacts mid corner without getting upset. I would highly such tuning service to anyone with adjustable suspension!
    k-moe and Chitwood like this.
  19. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Out of curiosity, what jet combo did you end up with?
  20. PavelK313
    Fairfield CA
    43/134
    Todd A Smith and Chitwood like this.
  21. PavelK313
    Fairfield CA
    Achieved a milestone of 1000 miles on the build.
  22. Uxbridge Brule
    Uxbridge Ont
    Oh to live in a good weather place.... rain and cold off and on here the way it going I'll be lucky to put 1000km(!?!) On my bike this season.
  23. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    What you need is an "Aerostitch" cold weather suit, amazing stuff. It's not cheap, but neither is a motorcycle that you can't (hardly) ride.
    Cheers, 50gary
    Uxbridge Brule likes this.
  24. PavelK313
    Fairfield CA
    12632269-7657-4915-B064-267B6BBA53D3.jpeg A18C91CF-AEE6-4B7F-94C6-85F23868D9A1.jpeg Went for a ride today and snapped couple of pictures of the bike.
    Chitwood and k-moe like this.
  25. PavelK313
    Fairfield CA
    Decided to take a bike for work today instead of a car, due to it being Friday and it was during rush hour traffic. On the way back I ended up going through a tunnel and did 2nd gear WOT pull, bike sounded orgasmic in the tunnel!
    k-moe, Chitwood and XJ550H like this.
  26. Polock
    bet that made them look up from their cell phones
    PavelK313 and k-moe like this.
  27. PavelK313
    Fairfield CA
    Ever since buying my XJ, I always disliked how quiet horns are on this bike (not sure if it’s just mine or all of them) and after yesterday’s ride through traffic I realized that cars probably can’t even hear my horn. So I swapped out stock 2 horns for original single horn from my 2006 R1 donor bike.
    Now I finally have horn that’s beyond adequate!
  28. Timbox
  29. PavelK313
    Fairfield CA
  30. PavelK313
    Fairfield CA
    5AE999B5-CDE7-45DE-BE59-6F33A971EF73.jpeg Got spotted by a friend today.
    Crappy picture but you can tell the size of the bike.
    Uxbridge Brule and k-moe like this.
  31. PavelK313
    Fairfield CA
    Run out of gas today and had to push bike 3.5 miles to nearest gas station. I guess I ridden it little harder than usual since I run out of gas 15 miles sooner than ever. Anyone has suggestion on how to modify or what petcock valve to get in order to get reasonable reserve? I am not sure if something is wrong with my petcock valve or if it’s due to the angle of the tank but I only get 1.5-2 miles on reserve.
  32. XJ550H
    MattiThundrrr likes this.
  33. XJ550H
    depends on the tubes in the tank you could make the reserve taller and the on tube taller end up switching over earlier
    long ago I used to carry a canteen full of gas
    27 oz
    https://www.ebay.com/itm/27-fl-oz-U...=123669257847fe0efc6a2aec456c9c320128839b401d
  34. XJ550H
  35. k-moe
    Do you remember the thread where you mentioned leveling the tank?
    Well, that's the result; a smaller reserve.
    I don't think you'd want to alter the pickup level for the reserve since that would leave you with almost nowhere in the tank for water and detritus to settle out.
    If I were going to alter the tank it would be on the topside, and somewhat a PITA to layout, cut, and fit (who am I trying to kid? It'd be cut rectangular and I'd make it ugly on purpose). Making the tank about 2" taller would add enough volume that you could use a manual petcock with brass feed tubes cut to your desired heights and not only gain more reserve but gain more overall range.
    A 1 liter MSR bottle would look good strapped to the rear downtube. Mine lives in the left storage-tube that I made (which would not look good on your bike at all). MSR botttles solve all sorts of problems (like not having the patience for rolling compound curves into steel sheet).
  36. PavelK313
    Fairfield CA
    Most definitely don’t have any space what so ever under the tank, since that’s where my buttery, front control connectors, horns, starter relay, all the grounds and the rest of the wiring resides.
  37. PavelK313
    Fairfield CA
    I do remember that thread, but you know what... no RAGRETS! Hahaha (misspelled on purpose)
    I most definitely don’t want to modify tank or shape of it. Extra frame mounted bottle of fuel isn't a bad idea, but I feel like it’ll mess with lines on the bike. :/
    Conclusion will be to stick to ~100 mile fill up intervals. I was used to 135-140 mile fill up until today. :/
  38. k-moe
    Coolness has its price.
    Uxbridge Brule, Timbox and PavelK313 like this.
  39. PavelK313
    Fairfield CA
    100% agree!
    I am willing to pay it!
    When I started building my bike I fully realized that it won’t be 100% polished out version of a motorcycle that Yamaha intended it to be, but after making so many changes and the only negative is almost inexistent reserve, I am ok with that. I did better than most.
  40. k-moe
    Here's a thought, and it would solve your sliding-off problem too.
    At one point (pre 1940) there were several manufacturere of smaller displacement machines who incorportated spare fuel tanks into their designs. Some ugly, others fairly good looking. There are also long-distance riders who have developed a market for auxillary fuel tanks (none would be suitable for your machine though).
    SO...
    Tail cowl. Possibly detachable. Also fuel tank.
    Downsides: Would have to be fabricated to suit. Adds weight to the rear. Could be plumbed into the fuel system so you can switch to it without needing to use it like a gas can.
    Upsides: No more sliding off the seat. No more pushing the bike to a gas station.
  41. PavelK313
    Fairfield CA
    Done longest/furthers ride on this bike today.
    Bikes performed as expected. Covered first 98 miles before stopping for fuel in 1 hour and 8 minutes, calculated Fuel economy and came up with 30mpg, which isn’t bad considering the style of riding I do. RPMs were in the range of 6000-9000+ Most of the time and didn’t have a single issue. Really curious to check oil level once bike cools down and oil settles, since it’s first time when it was kept at high rpm for such long time.
  42. PavelK313
    Fairfield CA
    Sooooo...
    Went for a ride today and when coming home, stopped at stop light and idle first was stuck at 2k rpm. This was news to me since before that moment I haven’t had any issues with idle. Pulled into garage, same thing. Did some diagnosing and came up with leaking throttle shaft seals. :/
    Already emailed Chacal for a set of new seals.
    Perhaps beating on the bike brought on a light on this issue.
  43. XJ550H
    it was all that working of the throttle that did it;)
  44. Polock
    you went 98 miles in 68 minutes, give it about 15 minutes and those throttle seals will catch up with you :)
  45. 50gary
    Saginaw, Mi. USA
    98 in 68 is very fast. 86.47
    Cheers, 50gary
  46. PavelK313
    Fairfield CA
    And now I am paying for it. Haha
    Parts should come in on Monday. But I probably won’t be able to get to do it until Tuesday or Wednesday.
  47. PavelK313
    Fairfield CA
    Update. Recieved parts from XJ4EVER yesterday and put them in today.
    Bike is back up and running as should.
    XJ4EVER emailed me a link to DIY on how to change throttle shaft seals. It’s very detailed DIY however I am the type of person that can’t follow directions and if DIY has more than a handful of steps I get confused and start to overthink the whole process. So I went in it and tried to figure out on my own.
    From what I have read before made me believe that doing this job will be very complicated, however after doing it myself I must say it’s a lot easier than I though.
    From start to finish it took less than 2 hours.
    One thing I must mention is that for some reason after replacing seals and fuel line O-rings between carbs I had to turn fuel mixture screws out half a turn to make bike run right.
  48. k-moe
    Out half a turn is weird. Normally you'd need to lean them up.
  49. PavelK313
    Fairfield CA
    That’s my exact thinking. After replacing seals (which were providing air leak) bike actually started to run slightly lean. Makes no sense to me but that’s what I did.
  50. PavelK313
    Fairfield CA
    748D692A-AC79-4B20-8BDA-6F6EB3ABD24A.jpeg Mocked up a windscreen to clean up the front end. What do you all think? I am not completely set on keeping it.
    Franz, McTavish and Chitwood like this.
