softer clutch pulls
Discussion in 'XJ Modifications' started by amiel1157, Aug 6, 2022.
  1. amiel1157
    amiel1157 Member
    Philippines
    want easier clutch pulls? try the lambretta "brake arm" they are longer hence more leverage i dont know the exact name of the part. it fits perfecty and clutch pulls are VERY soft compared to original.
    Franz likes this.
  2. faffi
    faffi Active Member
    Norway
    Interesting idea. That was a massive extension, that should almost reduce the required effort in half. It also means a lot more travel is required for the same clutch operation, and the engagement point will be much wider - which can be both good or bad, depending on the original feel.
    amiel1157 and Oblivion like this.
  3. hogfiddles
    Why not try lubricating the cable? These aren’t big clutches....
    cgutz and chacal like this.
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Yep, makes a big difference.
    cgutz likes this.
