Something different...
Discussion in 'Hangout Lounge' started by Huntchuks, Nov 10, 2025.
  1. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Well, I went in 1/2 with my son to get a cheap boat. I will need to work on the motor, a 1992 Yamaha XR-6 150 HP. Look at that monster and wish me luck.
    Franz and Roast644 like this.
  2. Huntchuks
    East Rochester, NY
    It's a 6 cyl. 2 stroke with oil injection. I haven't run it yet but did a cold compression test and all cylinders were between 110 and 120 psi.
  3. chacal
    Wall-to-wall cars in that garage, too...............
    Timbox likes this.
  4. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Nice. I'm not a boat guy at all, but my son bought a bass boat with the 3 cyl 75 hp version of that motor and I learned more about it then I wanted to. Definitely a different animal than cars and bikes.
    Huntchuks likes this.
  5. Fuller56
    Fuller56 Well-Known Member
    I noticed that too, it needs more explanation and exploration. And pictures.
  6. Huntchuks
    East Rochester, NY
    Ok, Ok, here are some photos I took when I picked up the boat. 20251028_161754.jpg 20251028_162458.jpg
  7. Huntchuks
    East Rochester, NY
    There are more but I was getting errors trying to upload them.
  8. ksigurdsen
    ksigurdsen Member
    Wellington, FL
    Sweet! I never had a desire to own a boat until one came along as a “gift with purchase” after I became unmarried and bought a house earlier this year. The boat is a 2001 Angler 180 Center Console with a Yamaha F90. The motor purrs like my XJ750K.
  9. Huntchuks
    East Rochester, NY
    co.dirtbiker likes this.
  10. chacal
    on the top row Eye-Spy:
    - a white Corvette
    - a silver 55-57 Belair
    - a blue '70 GTO (probably a Judge option, because of the stripes)
    - a white 1971 Plymouth 'Cuda
    - a gold 1971 Plymouth Cuda
    - a red 1971-72 Chevelle SS
    - a brown 1970 Dodge Coronet (probably a superbee, maybe a convertible?)
    - a dark-colored mid-70's El Camino
    - something else that is too hidden to ID, but maybe a 1990's Camaro or Firebird
    - the Pace Car Corvette is a 1978 model
    Lots of other interesting stuff in there.
    ksigurdsen likes this.
  11. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    I dig the bullnose Ford over by the Chevy pickup and the white Buick convertible in the top picture.
  12. Fuller56
    What a great collection of Big Boy Toys, or Big Girl Toys, just to be politically correct. But I do question the description of "cheap boat". I was under the impression that was an oxymoron. Sort of like "free motorcycle".
    co.dirtbiker, Brhatweed and chacal like this.
  13. Huntchuks
    East Rochester, NY
    The motor wouldn't run, so I rebuilt the fuel pump. Now gas flows good but still no engine firing. Pulled the carbs to rebuild and found the float needles, which point down, were stuck in the seats enough where I suspect no fuel could get into the bowls. One bowl for two carb unit system. The new needles had simple wires included, which I attached and allows the float to actually pull the needle up from the seat. The originals relied on fuel to push the needles up/open. Carbs cleaned, assembled, torqued. Pulled the reed valve adapter plate and inspected/cleaned the reeds. All in great shape. Waiting for the large reed valve adapter plate gasket to arrive so I can reassemble everything. Problem is...it's cold outside.
    Fuel pump...
    Carbs...
    Carbs, adapter plate and reed valves...
    Roast644, Fuller56, Brhatweed and 2 others like this.
  14. Franz
    What you fishing for when you get it fixed?
    Brhatweed likes this.
  15. Huntchuks
    East Rochester, NY
    Mostly Bass.
    Brhatweed and Franz like this.
  16. Huntchuks
    East Rochester, NY
