Somethings not right
Discussion in 'XJ Technical Chat' started by Tanner Petersen, May 12, 2018.
  1. Tanner Petersen
    Tanner Petersen New Member
    Perham MN
    I've been working on an 81 XJ550 Maxim trying to get it running so I can enjoy the good weather. I've gone through the carburator and synced it,replaced cables, adjusted the chain and numerous other minor things. My problem is I finally got to take it for a test drive around the block which went fine. The next morning I went out to start my bike and there was nothing but a single click from the starter solenoid and it made my neutral light shut off. I checked fuses and and cleaned all the connections I could find. Also made sure the battery had power and unplugged and replugged in any spots where the wires came togethor in case there was any corrosion. Tried jumping the solenoid but all that did was make a spark and shut off all power again. It wont shift up or down either for some reason just kills the power when I try to shift. This is my first motorcycle and everything was going really smooth up until this point. Hopefully someone can chime in with an answer
  2. Tim O
    Tim O Active Member
    Charlottesville, VA
    I think killing the power when you shift out of neutral is kickstand down switch?
  3. XJ550H
    if you shift it into gear with side stand down you must pull in clutch . the safety feature will kill power to ignition if you have a bad or missing clutch safety switch
    battery must be fully charged if it is to low solenoid will only click and if it drops below 10 volts when cranking bike will not stark
    just having side stand down and shifting into gear may also kill the ignition.
    my switch is disconnected. so my bike will only start in neutral and when I deploy the side stand bike shuts off
  4. Tanner Petersen
    Perham MN
    Maybe I have a bad battery then because the regular kickstand is up
  5. XJ550H
    bad batterys happen a lot
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Try jumping it with a car battery.
  7. XJ550H
    do not start the car
  8. Tanner Petersen
    Perham MN
    Thanks for the help Ill let everyone know how it goes tomorrow
  9. Tanner Petersen
    Perham MN
    It was a bad battery because it turned over right away after i hooked it up to my car. Still doesnt explain why it wont come out of neutral though. I'm going to start digging through the forums for answers unless someone comments on here first. Thanks everyone I was really worried it was a wiring issue somewhere
  10. XJ550H
    look at the mechinisims behind shifter cover you may just have a broken spring
  11. Polock
    are you rocking the bike back and forth when you try to get in gear
