Spark
Discussion in 'XJ Technical Chat' started by Loganxj, Apr 1, 2022.
  1. Loganxj
    Loganxj New Member
    Weare nh 03281
    Hey guys, I have a question, when I flip my Killswitch is the plugs supposed to spark? I've never seen this before and just curious thanks!
    Leif Harrington likes this.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    yes, that can happen, the spark comes from the stored energy in the coils, flipping the kill switch, is similar to the breaker plate passing the pick-up coil .
  3. Leif Harrington
    Leif Harrington New Member
    Tulare, California
    Having a similar issue: while cranking over I have no spark, but when I I flip the kill switch it will spark (only once but a spark none the less).
    Checked and charged battery, it's good. So could it be the starter is robbing to much of the power for the tci to operate then when switched off theres a surge of power causing a single spark at the plugs??
    Any advice/help is greatly appreciated, thank you.
  4. Fuller56
    Fuller56 Well-Known Member
    Yes, that is exactly correct. Put a voltmeter on your battery while operating the starter to verify the voltage. The TCI requires at least 10 volts to fire the ignition. It is not unusual for the battery to have enough energy to operate either the starter or the ignition but not both. Have you tried push starting the bike?
