Special Tools (in UK)
Discussion in 'XJ Technical Chat' started by DaygloDavid, Nov 28, 2022.
  1. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    Having now had these special tools manufactured for use in the partial disassembly and assembly of the final gear unit on my 4K0 (UK) XJ650.
    Does anyone in the UK have the other tools required to fully complete the job. They are available from Fowlers but are rather expensive.
    There is a slide hammer (can't find a photo)
    External 9089001290 ARMATURE SHOCK PULLER (fowlersparts.co.uk)
    External 9089001291 WEIGHT (fowlersparts.co.uk)
    and this adapter required too.
    Slide hammer and adapter in use.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    hi, cant help with the other pieces , but Machine Mart have the slide hammers ,but they are around £70 , maybe a hire shop can supply them
  3. DaygloDavid
    The slide hammer has an M10 x 1.25 thread and the adapter converts M10 x 1.25 to M14 x 1.5.
    [​IMG] [​IMG]
    The latter being the thread on the end of the pinion once the coupling gear has been removed.
    This guy uses a pair of screw drivers rather than the slide hammer and adapter to remove the pinion.
