Spring Identification
Discussion in 'XJ Technical Chat' started by wcd, Aug 26, 2018.
  1. wcd
    wcd New Member
    Canada
    Yes yes, I know. One of the golden rules of mechanical work is to stay organized and tidy... However, here I am, spring in hand, with no idea from whence it came. Maybe a shot in the dark here but I'm hoping you folks can help me to ID it.
    I just finished a full rebuild of the carbs and on my work bench there was leftover a single brass coloured spring. I dont thiiiink the spring is actually from the carbs though. (not: diaphragm spring, idle mixture screw spring, throttle return spring, spring in the piston holding needle down, synchronization screw springs, idle set screw spring). I've also been doing other little odd jobs along the way too though. So maybe it is from one of those things. I tried to show some sizes of the spring in the pictures to get a better chance of IDing it. Here's a list of oddjobs i had going on at the same time that it might be from as well:
    -Full front brake rebuild, (calipers, lines, MC)
    -Fuse panel replacement
    -Turn signal switch cleaning and de-stickyfying
    -spark plug and boot replacement
    -new rubber on both wheels and necessary removal of wheel and tires from bike
    -battery removal
    -petcock rebuild
    -vakve shim adjustment
    - rear brake drum and shoe cleaning
    -... Maybe some others that I've forgotten about...?
    I can't for the life of me figure out where it goes. I know as soon as someonefigures it out it'll be a "duh of course" kinda moment. Hopefully you folks known what youre talking about more than me! (and that's not saying much!)
    Also, it's an 82 XJ750 Maxim.
    15353305842431588015932.jpg 15353306474781396464225.jpg 1535330754879152316591.jpg
  2. chacal
    I know that you said it was NOT from the carbs, but it sure looks like a synch screw (or plunger rod) spring to me.........
    For reference:
    HCP45
    OEM Hitachi HSC32/33 throttle synch screw SPRING
    OL: 12.25mm
    OD: 7.83mm
    ID:
    Wire: 1.20mm
    open ends
    Finish: yellow zinc plated
    HCP46B
    OEM Hitachi HSC32/33 throttle synch rod SPRING
    OL: 12.20mm OL
    OD: 7.50mm
    Wire: .90mm
    flat ends
    Finish: yellow zinc-plated
    HCP84
    OEM Hitachi HSC32/33 idle speed bolt SPRING ONLY
    OL: 20.00mm
    OD: 7.94mm
    Wire: 1.20mm
    flat ends
    It appears to be about 3/4" OL x 5/16" OD which would match the HCP84 above............
    Colin 85 700 and Jetfixer like this.
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I was thinking that it looked like a screw spring, so I’m with Chacal.
  4. wcd
    wcd New Member
    Canada
    Hmmm so is that the spring for the idle adjustment screw you think? Like the one that you turn by hand to adjust idle speed?
    I definitely have a spring there already, but heck, maybe that one's in the wrong place... In which case Ill have a new spring to identify.... Damn it!
  5. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    No, not specifically, there are four of these, one on each carb, between the sync screws and the er.. linkage?
  6. hogfiddles
    No, there's only 3.
    1st between carb 1 & 2
    2nd between carb 2 & 3
    3rd between carb 3 & 4
    It looks like the lower spring. You should have two on each synch location. The top spring is the heavier one, the bottom spring is the lighter-weight spring.
    Dave F
  7. wcd
    wcd New Member
    Canada
    So I was pretty darn certain that I had replaced all of those in the respective spots, and all 6 of them are there and doing dandy. Those springs I'm quite confident in being the right ones too. I was pretty particular about getting those specific screws and springs all back in the same order and in their respective positions. Plenty of notes and pictures taken of those areas.
    The spring I've got seem like it would be too big to fit in there... And it has a fairly high spring rate to it as well, heavier than what I think those sync screw spring use.
  8. k-moe
    Agreed. Yours is of a much larger diameter.
  9. hogfiddles
    And too long......those springs are only about a cm long (barely 1/2 inch). Must be from some other project
  10. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Allmost looks like the spring in the brake master cylinder to me....
    Being so shiny this may be a new one from the kit you used, did you re use the original?
    Did the kit come with two springs for different models and you have a spare?
    IDFK other than that
  11. Colin 85 700
    Thunder Bay, ON
    After reading descriptions from chacal, I agree with it being from the idle speed screw, adjust or knob.
    It's probly too small for the brake master.
  12. hogfiddles
    It's not the idle speed spring. Idle screw springs are MUCH heavier
  13. tabaka45
    Brunswick, Georgia
    I think it is a spring put there by his wife just to bug him.
    wcd, chacal and hogfiddles like this.
  14. wcd
    wcd New Member
    Canada
    Hmm..ill have to take a look into both of those. Any idea if the idle adjustment screw can come.out with the carbs on the bike...? I would love to not have to extract them yet again. Not a fun job.
  15. hogfiddles
    Idle adjustment screw will fall right off when you take the idle adjust meant screw put. Here is a pic of one in place. You can see it's much heavier than what you showed.
