Start button just clicks
Discussion in 'XJ Technical Chat' started by Ribo, Nov 17, 2015.
  1. k-moe
    Ya do that, and have the battery load tested (it's free) just to be sure. Even brand new batteries can fail.
  2. Ribo
    Ribo Prefectionist
    Cool - good idea. I'll take it to autozone tmw. I'm happy the motor appears to be good now - when it's getting voltage it fires the bike right up. The replacement brush kit was well worth it. Nice to replace the 35 year old rubber seals too. The comutator was seriously dirty and pitted - I got it nice and clean and smooth with some glass paper and gave the whole thing a nice clean and lube where needed. I like that good feeling of knowing another part of the bike has been restored to perfect working order. Thanks for all the help. Tskaz's write up was awesome. I found an old egg box came in handy for standing the unit up while putting it together.
  3. Ribo
    Ribo Prefectionist
    ok - so this is odd.
    I replace the solenoid and everything was great - for about a week or so. Then today I rolled it our the garage - it the start button and it just clicks again - then I notice a whiff of smoke coming from under my right leg. Damn it!
    Took a reading from the solenoid and it's basically not passing anything. With MM black probe on the battery negative and red-probe on the battery side of the solenoid I get 12+v -- with the red probe on the other side of the solenoid I get zero -- press start and i hear clicks but nothing on the MM. Then all of a sudden smoke coming out the solenoid...
    So...I'm thinking maybe the wire from the solenoid to the starter motor is bad and caused the new (and old) solenoid to burn out? If I touch that wire to the battery positive it should start the bike right? ( cos it doesn't).
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Dumb question...are you certain all connections at the solenoid are correct?
    Gary H.
  5. Ribo
    Ribo Prefectionist
    I believe so but a photo of howit should look would help me remove any doubt.
  6. XJ550H
    hard to reverse wires ( color coded) unless he modified the connector. and its a coil for the relay it would still work
    and reversing the Battery + wire (Top bolt) with the Starter wire ( Bottom bolt) would not cause a problem
    at this point you should check out the starter button switch , starter circuit relay that could be what smoked.
    also check kill switch to ground and solenoid
    red white wire runs from fuse to starter switch then down to starter circuit relay then up to the solenoid
    the blue white wire runs from solenoid to engine kill switch to ground
    I think your solenoid has failed again
    i get 3.6 ohms across the blue and red wire for the coil.
    I think my wiring diagram is incorrect listing starter switch as kill switch and vise versa
  7. XJ550H
    did you ever confirm running voltage?
  8. Ribo
    Ribo Prefectionist
    yeah it was like 12.60v.
    Question - someone said early on here that if I was to short across the solenoid with a heavy screwdriver the bike should start - I did that when it was working with the push button and it didn't start at all -- but pushing the button did start it.... for a while. This makes no sense to me.
    If I take a thick wire and run it from the positive on the battery to the starter motor - shouldn't that turn the motor also?
  9. XJ550H
    if you jump the 2 heavy wires together and the starter is not spinning it is a starter problem or the wire from the starter has failed.
    disconnect the wire from the starter hook your meter to that do a continuity test from solenoid connection to starter connection.
    yes
    the 2 wires with the blue arrows are the coil of the solinoid
    the wires marked x1 connected to battery and x2 connected to starter
    if you jump these 2 wires together starter should turn
    disconnect +wire from battery for saftey
    disconnect the x1 and x2 from solenoid
    1)check battery wire x1 connector to battery connector. continuity test or ohms.
    2)hook your meter to x1 and x2 ON SOLEINOID continuity test or ohms.
    turn key on press starter button you should have a squeel for continuity or 0 ohms
    3)test continuity from starter wire Connector x2 in my drawing to starter BOLT again squeel for continuity or 0 ohms
    4)test ohms from blue wire and red white wire should be about 3.6 ohms
    let me know what you got for results
    what you are testing for is
    1) bad battery wire connector
    2) bad starter wire
    3) failed solenoid
  10. Rooster53
    Smoke coming from the solenoid obviously indicates excessive current through the solenoid contacts. I couldn't quite see from you original pictures of your starter, but I believe you mentioned the brush wires had burned, which again indicates excessive current. Or was the burn just mistaken for the blackened carbon buildup from the brushes? Four reasons for excessive current.
    1. Shorted windings in the starter armature
    2. Armature windings shorted to ground
    3. Mechanical failure locking the starter. The starter initially draws a tremendous amount of current, but this is quickly reduced by back EMF as the starter spins. The faster it spins, the less current it draws. If for some mechanical reason (bad bearings, gears, etc.) the starter does not spin it will draw maximum current and overheating in the starter circuit occurs - starter, wiring, battery, and solenoid.
    4. The positive terminal insulator and washers on the starter are compromised allowing 12V to be applied directly to ground
    Anyway, my guess right now is that you have a defective starter with some damaged windings. About all you can do to verify is check the commutator segments to ground. The actual resistance of the windings is so low that the DMM is of no use to isolate shorted winding and you would need to have the armature checked by a motor shop with the proper equipment to verify 100%.
    Here are the excerpts from Len's electrical guide on checking the windings. You can find the complete list in this link near the bottom:
    http://www.xjbikes.com/forums/threads/xj-parts-catalog-section-d-electrical-system.44641/
    Step (c) and (d) are meaningful, with step (d) mostly as mentioned above for commutator segments to ground. Step (e) is not going to yield good results with a standard DMM.
    c) check the raised segments for continuity between each individual segment and each and every other segments. There should be continuity.
    d) check for continuity between every segment (assuming the test in "c" above has already been performed) and the shaft of the armature. There should not be any continuity.
    e) check the resistance of the internal coil windings of the armature. You do this via measuring the resistance across every two adjoining segments. It should be:
    * 0.012 ohms +/- 6% at 70-degrees F. for all XJ550 starter motors.
    * 0.014 ohms +/- 6% at 70-degrees F. for all XJ650, XJ700, XJ750, and XJ900 starter motors.
  11. Ribo
    Ribo Prefectionist
  12. rocs82650
    Middle Tennessee
    Unless there is internal damage the motor should be fine. Bad electricals doesn't mean the motor is ruined. We just need to find the problem.
    Gary H.
  13. k-moe
    Starter motor I assume; not engine.
    The starters for all the 650/700/750 series are the same.
    Have you torn the starter motor down for inspection? They can be rebuilt (though it's not economical if it needs rewound, given how many used ones are available).
  14. rocs82650
    Middle Tennessee
    Doh! Thanks k-moe.
    Gary H.
  15. ddecdoc
    ddecdoc New Member
    After reading about that guys electrical problem maybe mine will be a snap! I have the same click from the start button. But according to my schematic there is an oil level switch that I cannot seem to locate on this bike. (86 xj700X) and so you know, I bought this bike in a basket. So I am putting it together from scratch. I have everything functioning except the start button and it is driving me crazy!! Any suggestions would be greatly appreciated.
  16. Ribo
    Ribo Prefectionist
    Yeah I took it fully apart and gave it a good solid clean and replaced the brushes / whole internal part where the brushes sit. It worked again for about 3 days and then died again.
    I took a think piece of insulated wire from the battery positive and touched the connection to the starter motor and not only did it not start but the wire started getting very hot. Indicates to me that the coils just aren't getting or using the electricity thus it's overloading the wire. Probably the reason why two solenoids have burnt out.
    I'm pretty sure it needs to be rewound.
  17. Ribo
    Ribo Prefectionist
    Any relay can be bypassed if you trust yourself enough.
  18. k-moe
    ddecdoc,
    The oil level switch is on the bottom of the oil pan, and hidden from view by the exhaust collector. It has nothing to do with the ignition or starter system.
    Start a thread so we can diagnose your particular problem.
  19. ddecdoc
    ddecdoc New Member
  20. ddecdoc
    ddecdoc New Member
    I can't figure out how to start a thread. Man do I feel like an idiot!!
  21. k-moe
    Stumplifter likes this.
