Starter Button is sticking
Discussion in 'XJ Technical Chat' started by idle_purr, May 25, 2023.
  1. idle_purr
    idle_purr New Member
    NY
    I am working on an 86 Maxim Xj700
    When I push the start button it sticks in the on position and I have to pull the button out. I have taken it apart and cleaned it but that did not improve anything at all.
    This is the exact starter switch that I have, the gray button inside is soldered in there, I was hoping to find just the gray button and the small assembly that goes with it.
    Does anyone have any suggestions on how to fix it?
    I was also wondering if anyone knows if you can buy just the button assembly?
    I have been having trouble locating parts, I appreciate all the help I can get.
    Thank you!
  2. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    idle_purr likes this.
  3. Dan Gardner
    Minneapolis, MN
    I had the same thing happen on a 700. For me cleaning and lubing did the trick
  4. idle_purr
    NY
    What did you use to lube it with?
  5. JPaganel
    Minneapolis
    Ok, with the addition of the picture I see it is not the round button, so my first suggestion does not apply.
    As far as lubrication:
    Try silicone grease.
    It is dielectric, and will not stain like regular grease.
  6. Bryce W
    Bryce W Member
    Virginia
    I had to clean mine twice to get it to not stick, I think after a while the plastic wears and the button binds a little.
  7. Dan Gardner
    Minneapolis, MN
    Dielectric grease if I remember correctly.
  8. idle_purr
    NY
    I went out this morning with a fresh mind and took it apart again, I cleaned the button and assembly really good and greased it with Dielectric grease in all of the pivot points and where it might slide on other plastic. I also put grease in the tiny hole where the spring and little ball bearing are. Well to make a long story short my button is now as smooth as butter and all reassembled.
    Thank you very much everyone for the advice.
    I am guessing I will be around here for a while now that I have my XJ
    JPaganel, Oblivion and Huntchuks like this.
  9. Bryce W
    Bryce W Member
    Virginia
    Yep, I used dielectric grease as well. Every once in a while my button will stick a little, so dont forget completely just in case.
