STARTER RELAY OR BUTTON ISSUE?
Discussion in 'XJ Technical Chat' started by Sam S, Nov 7, 2021.
  1. Sam S
    Sam S New Member
    Colorado USA
    I have an 82 XJ750J which has been giving me problems when I push the starter button. I have to wiggle it around while depressed to get the bike to fire up.
    Thinking it was the button, I pulled it apart and cleaned the contact points, put it back together and it just wouldn't work at all except I heard a small clicking noise which is coming from the (round) relay, just aft of the battery.
    Now I'm thinking the relay solenoid is the issue. I found some on EBay for about $11.00 new (w/shipping). I Don't think it's OEM (Paul Eagle brand?), but for 11.00 might not hurt to replace it.
    If anyone has encountered this issue, any comments are appreciated.
  2. Franz
    Try the following.
    Battery voltage check.
    Make sure handlebar is clean where the switch contacts it. Your starter switch grounds to the handlebar.
    Fuse box, is it original you are better with blade type fuse box. Original ones the clips break.
    Bridge solenoid with a screwdriver to see if engine turns over with ignition switch on.
    Sam S likes this.
  3. Sam S
    Sam S New Member
    Colorado USA
    Thanks for the reply. I'll try bridging the solenoid first. I did wipe down the handlebar under the switch but maybe not enough.
    Everything is original and very clean.
    No probs w/fusebox but good info. I do get a tail light warning sometimes but it goes away after a little while.
    The battery was at 11.98v and had not been riden for a couple weeks and trying to start it drained it a little more so I trickle charged it but no diff.
    I've had the bike for 25 years with hardly any problems.
  4. Franz
    The battery needs tested under load. Try a car battery and jump leads with the car engine not running. You need 10 volts minimum when the engine is cranking on the starter to get sparks at the plugs. I know your bike starter is not spinning but it might with the car battery. Also check the voltage at the two pin plug going to the solenoid with a multimeter. Good luck. Might be voltage drop caused by a wire at the switch. Wiggling the wire then it starts is a red flag. Might be a damaged wire.
    Sam S likes this.
  5. Sam S
    Sam S New Member
    Colorado USA
  6. Sam S
    Sam S New Member
    Colorado USA
    So, I shorted the solenoid and it cranks engine every time. Took off starter switch and sandpapered handlebar contact area. No diff there. Pulled tank and checked for insulation/wire damage. No obvious damage there. Hooked up car bat w/engine off), and no diff.
    I did pull starter switch apart again...looks good. (actually shiny-no rust at all) When I depress the starter button , and wiggle the button (not wire), a bit, it will crank engine. If I push starter button in and let go slowly it will catch sometimes about half way out. Tried wiggling wires w/button depressed to see if any change but no diff. I'm leaning towards a bad start switch even though it looks ok. Springs for contacts have good tension/pressure, contacts are clean with only slight scoring. Wires, connectors and soldering look fine from switch to solenoid.
    Battery also has full charge and turns engine over easily...when it works.
    I'm actually thinking of either getting another starter switch somewhere or tapping into the two wires that close the circuit and putting in an alternate start button which is far better than pulling out the rest of my hair. Ebay has a couple starter switches but they look pretty bad. (One looked like it was half melted in a fire)
    Mine looks like new inside and out. I tried to load a couple pics but got an error message.
  7. Franz
    Yup must be the switch. One of the members here might have a spare or you can fit another switch as you stated.
  8. Jeff Witt
    Jeff Witt New Member
    Port Washington, WI
    What exactly do you mean by bridging the solenoid? If you short across the terminal lugs you will not test the solenoid that will simply bypass the solenoid to test the starter. If you activate the solenoid with 12 volts to the small terminal that will actually test the solenoid. If it clicks but does not crank the engine then the magnet may be working but the connection is not being made. After many years of use the contact bar inside can arc enough to stop the connection from being made.
    Sam S likes this.
  9. Sam S
    Sam S New Member
    Colorado USA
    Thanks Jeff, This problem has been getting worse over a long time and has finally hit critical mass. The old addage, "Don't fix it unless it's broke" may not have been the best approach. Kind of like putting off going to the dentist.
    When I push the start button (now), I usually get a clicking in the relay but no cranking. After 39 years I wouldn't be suprised if the connections in the relay have worn down which would fit the slow degradation profile. For 11.00 bucks I don't mind replacing the solenoid.
    As you hopefully can see from the pic of the starter switch housing, it looks like new.
    After thinking about it, I won't be putting in an alternate start switch since I can't disable the 'run position' (button not depressed) circuit and would need to push two buttons to start it - if that makes sense.
    Jeff Witt likes this.
  10. Jetfixer
    Replace the starter solenoid!!! I had same issue my starter solenoid had corrosion inside housing , these are cheap in fact ordered two so I have a spare.
    Sam S likes this.
  11. Sam S
    Sam S New Member
    Colorado USA
    Thanks Jetfixer, Just ordered it.
  12. Carl LaFong
    Carl LaFong Member
    ontario
    Ditto. The p.o. Replaced the starter button. Did not fix issue, when I got the Bike replaced solenoid problem solved. Good luck.
    Jetfixer and Sam S like this.
  13. Sam S
    Sam S New Member
    Colorado USA
    Thanks to everyone for all the helpful comments and experience. My hair is starting to grow back already.
    I will update when I have the 'thing' running again.
  14. jayrodoh
    jayrodoh YimYam
    Cleveland
    Pretty classic symptoms of a starter solenoid that failed. They get pitted/burnt up inside and eventually will not close the circuit even though the relay coil is pulling in. While you have it out to replace, make sure your connections are clean at the battery, solenoid, and starter lug to ensure a good connection. Poor connections will heat up.
    FYI I've bought some cheap solenoids in the past that failed pretty quickly, not sure what you bought but in case that happens to you don't go pulling your hair out thinking you have another issue. Unfortunately Amazon and eBay are flooded with all sorts of cheap parts.
    Sam S and Franz like this.
  15. Sam S
    Sam S New Member
    Colorado USA
    Thanks Jayrodoh, Once I get it running I'll take apart the old one to see what's up. All the connections are clean.
    I probably got a cheap one just due to the price. Do you have a preferred source for a quality one?
    TIA
  16. garicao
    garicao New Member
    What Jayrodoh says. If you hear a clicking noise when pushing the starter button, it's solenoid noise, and the starter button is ok. If jumpering the two thick wires at the solenoid starts the bike, the battery is ok and you have a bad solenoid.
    Sam S likes this.
  17. Sam S
    Sam S New Member
    Colorado USA
    Thanks to everyone who helped with comments and experience. Just got new solenoid. Just got it installed. Works every time.
    New solenoid is about half the weight of the original. Maybe high tech or just cheap? For now, I'm happy to have it working.
  18. Sam S
    Sam S New Member
    Colorado USA
    So I disassembled the original solenoid. This is a one way job. You can see it's clean but the contact points are kinda worn.
    Thought I'd add a couple pics of bike too.
    Jetfixer likes this.
  19. Dan Gardner
    Minneapolis, MN
    I guess that is just worn enough to cause problems.
    Nice looking bike though! The seat looks extra luxurious.
  20. Sam S
    Sam S New Member
    Colorado USA
    Thanks Dan, Yeah, that's the original seat and that luxurious seat has some luxurious duct tape on the King part of it. Gorilla tape actually. The good stuff! The cheap stuff tends to slide in hot weather and stick to my butt.
    The day I got it running it was in the mid 60's. Today I woke up to 27F. Tonite it's going into the teens. Guess you're used to those temps up there.
    Soon I'll be replacing the front tire and bleeding the front brake. I can actually squeeze the front brake lever all the way down without going over the handlebars. A friend said I should take off the caliper and hold it up high to bleed cause bubbles have trouble going down hill. Nothing worse than bubble trouble. Can't bleed it fast enough.
    Then I'll pull the carbs off to change out the leaking boots to engine. I actually put my hand over the air box when running and nothing happened. It should have sucked my hand through the engine and spit it out the tailpipe. That's probably why it has trouble holding idle. If I get real crazy I just might try to fix the speedometer gears in the dash. Haven't had a speedometer in 25 years. I just pull up next to cars on the highway and look at theirs.
  21. Dan Gardner
    Minneapolis, MN
    Yes, unfortunately my bikes are resting comfortably for the next few months.
    One of the recurring themes with these bikes is the age of the brake lines. If you have squishy brake lever that might be part of the problem. I don't have that much experience personally - my winter to-do list includes rebuilding MC and caliper for my XJ650J, then replace brake lines when I put it together in the spring. It will be interesting to me to see how much different the brake feel is once everything is re-done.
    Sam S likes this.
  22. Dan Gardner
    Minneapolis, MN
    Another disclaimer - I'm no expert. But I would think if you had that much vacuum leakage on the intake side that you would have a hell of a time with carb adjustments and idle creep.
    Sam S likes this.
  23. Sam S
    Sam S New Member
    Colorado USA
    Good point on old brake lines. I'll see when I bleed them.
    I do get idle creep - at least it creeps to zero rpm if I don't hang onto throttle a bit when stopped. Also can't choke it more than half way cause it doesn't do anything the second half. Makes it a bear to start in cold weather.
  24. Jeff Witt
    Port Washington, WI
    Sam If I am reading this correctly you have an 82 with the original brake lines? Big Fitz put up a great post about Why you need to replace your brake lines. Those lines will be 40 years old in the spring they were made to last 4. After replacing my lines I found that reverse bleeding works very well. Get a syringe and crack open the banjo bolt at the master cylinder (highest point in the system) then push the fluid up the brake line through the bleeder valve rather than trying to push the air bubble down to the caliper. The bleeder valve will only get air out of the caliper piston. It also took a lot of squeezing the brake ever to expand the piston to the brake pad before I got any resistance on the lever. That is a tiny master cylinder and it does not move much fluid with each pull. But that is also what gives enough mechanical advantage to be able to stop your bike with just your hand.
    Sam S likes this.
  25. Sam S
    Sam S New Member
    Colorado USA
    Thanks again Jeff! I will definitely 'reverse' bleed to see if it improves. Then get some new line. Wow, only 4 years and I got close to 40.
    Thanks for the link to Big Fritz's post. Do you have a good source for the line?
  26. Dan Gardner
    Minneapolis, MN
    The safe option is always @chacal at xj4ever.com.
    I think it depends on model, but he's usually got several options including OEM and various aftermarket options.
    Sam S likes this.
  27. Sam S
    Sam S New Member
    Colorado USA
    Thanks. I'll see what he's got.
  28. jayrodoh
    jayrodoh YimYam
    Cleveland
    He sells both the stainless and standard rubber. FYI if you've never had stainless before, they do not flex like the rubber lines and noticeably changes the brake feel. Most of my bikes have stainless from Chacal and I like the change, just a heads up as it will have a little less travel and be less spongy if you go that route. They look cool too.
    Huntchuks likes this.
  29. ravenbut
    ravenbut New Member
    oklahoma
    that certainly is a gem of a bike. i honestly can't decide whether i like the red or the black the best., mine is experiencing the same solenoid problem yours was. gonna check it when this cold snap is over here in Pink, Okla.
  30. Sam S
    Sam S New Member
    Colorado USA
    I got a cheap solenoid on Ebay for 10 bucks. Works great. Also got a backup as someone said the cheapos don't last long.
    New problem is I lost both headlights?? Came back on briefly while riding but now gone. Fuses have continuity, all connectors tight and no obvious shorts.
    I almost bought a black one that looked awesome (same trim pkg), and great mechanical for 1400.00 but no room in garage. Not much room in the wallett either. I already have the black helmut to go with it too and a candy apple red one. Your black one looks great.
