Starter staying on
Discussion in 'XJ Technical Chat' started by Mark R, Dec 10, 2020.
  1. Mark R
    Mark R New Member
    Ireland
    Lads my starter stays on while the engine is running and staying on with bike turned off
    Any ideas
  2. dkavanagh
    Rochester, NY
    Stuck starter solenoid? Could try disconnecting it and shorting the wires yourself to start the bike (be careful!)
  3. Toomanybikes
    Tsawwassen bc
    Pinched wire ? Broken starter button? Unplug the wires to relay
    A stuck starter clutch is also possible, but EXTREMELY unlikely.
    Check the electrics first.
  5. hogfiddles
    Depending on your bike, you can pull the thumb switch back out. The button-type probably not, but if you have the lever type, just pull it back manually
  6. Jetfixer
    On the right side below the voltage regulator is the starter cut out relay , try unplugging and clean contact points .or replace it .
    Franz likes this.
