Stator removal
Discussion in 'XJ DIY How-To Instructions' started by Charles kelsoe, Feb 15, 2019.
  1. Charles kelsoe
    Charles kelsoe New Member
    Taylorsville,North Carolina
    Ok folks. I've run into a problem and I need your help. I recently bought a 1986 Yamaha XJ700 and am having to replace the stator. Do I have to remove the starter in order to get the stator out? Any help would be greatly appreciated!
  2. Toomanybikes
    Tsawwassen bc
    Yes it’s easier to pull starter to have access to stator wires with starter out of the way. But are you sure it’s the stator and not just the brushes?
  3. Charles kelsoe
    Pretty sure. But was going to either clean or replace the brushes as well. Thanks for the info
  4. XJ550H
    you should ohm out the stator first.
