Steering into a corner pulls hard
Discussion in 'XJ Technical Chat' started by cds1984, Oct 6, 2011.
  1. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Hi again more questions for you guys!
    What would cause the bike to pull into a corner as soon as you put a slight lean into it.
    At slow speed(20 or 30Km/h ish) it feels like I have to fight the handlebars from turning left if i lean slightly to go around a left hand turn and likewise with turning right.
    I replaced the wheel bearings and they feel smooth although a little tight and I've put new lower bushes and seals into the forks and they seem pretty solid and I re-packed the headset bearings which seem nice and smooth without play but in saying that there is something funky going on in that area I'm thinking.
    Any ideas appreciated as I couldn't seem to track down the 'steering troubleshooting FAQ' which I was sure must be somewhere about.
    Bearing? Forks? what do you think?
  2. MiCarl
    My Venture does that if the air in the front tire is only a few PSI low.
  3. cds1984
    Aha!
    I'm glad i didn't go on a high speed test(I only took it up to 60Km/h) because the tyres were a bit low...
    Front: 12psi
    Rear: 23psi
    Good info, as always, and thanks again :)
  4. PTSenterprises
    PTSenterprises Member
    yep, knew instantly what the issue was. I learned that lesson many years ago on my Ninjas. Now I carry a tire gauge on the bike at all times and check them before EVERY ride.
  5. cds1984
    Good call!
    I have a foot pump with a gauge on it which works a charm.
    The tyres have been sitting on the bike, on it's centre stand, for about 9 months now, damn time flies, and the last thing that went on were the tyres at that point. Because of the complete strip and build up, I have to admit the tyre pressure wasn't even on my radar when I took it for a test ride.
    Basics are basics no matter what though!
  6. bigfitz52
  7. cds1984
    Lol yes... don't do that! My bad!
