Sticking throttle?
Discussion in 'XJ Technical Chat' started by howitz, Dec 15, 2011.
  1. bigfitz52
    the question was "would it result in the throttle grip itself sticking in place?"
    NO, it wouldn't. He's tried this with the cable disconnected, IIRC. Sure, the throttle linkage can hold the grip back; which is what you're referring to. But it can't make the grip itself hang up; and that was the question.
  2. howitz
    howitz Member
    Salt lake city, Utah
    sorry, but where exactly should that thin washer be going?
  3. Bushy
    Bushy Active Member
    Between the throttle grip and the switch block that the throttle tube sits in. The washer goes on the throttle tube before you put the hand grip on the tube.
