Strange Idle and smell after bike hit
Discussion in 'XJ Technical Chat' started by e13design, Sep 9, 2017.
  1. e13design
    e13design Member
    Los Angeles, CA
    So my 1983 xj550seca was hit this week. The car struck my left exhaust and dented it, broke off the pass foot peg, and then the bike fell over on the right side.
    I'm ok, my right controls, foot pegs and that left exhaust pipe are bent and not looking so hot.
    So the frame is still solid, the rear tire and swing are are still true.
    The problem I have now is that the bike Idles weird, and I am smelling exhaust while at a red light.
    I'm trying to think about this logically, perhaps when it fell over and the gas leaked out that a float got stuck.
    Or there may be a separation or crack in the manifold that could cause this. (I'm thinking that would affect the engine running because when you change to a 4-1 system you need to rejet, I don't know now, just speculating).
    Thoughts?
    Feelings?
    What should I check first?
    gas will leak out of carbs when bike is on its side floats do not float properly when working sideways.
    check your oil level depending how long on side may have some fuel in the oil.
    also may be smelling battery acid . wet cell battery or AGM?
  3. e13design
    e13design Member
    Los Angeles, CA
    Gel battery.
    Oil level good.
    I should probably tap the float bowls to make sure they are not stuck.
  4. jsngrimm
    jsngrimm Member
    Akron,Ohio
    Check out the header pipes and where they meet the engine, something may have gotten damaged causing an exhaust leak somewhere. My 650 Maxim had a leak for a while and it wasn't huge but it actually didn't really run noticeably different
  5. k-moe
    Check everything. Not all damage is obvious. Eyeball every square mm of the machine; slowly and methodically.
    Stumplifter likes this.
