Strange Spring
Discussion in 'XJ Technical Chat' started by Ian Green, Mar 7, 2021.
  1. Ian Green
    Ian Green Member
    Antrim
    Ok so now i have the electrics sorted. Front forks Rebuilt. Front and rear brakes rebuilt with new stainles hoses But giving the bike one more quick check i noticed a spring hanging from the back of the right hand side rear passenger foot hanger and for the life of me i can't see where it's meant to go. It's not the brake pedal return spring and i am at a loss anybody have any ideas
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    brake light switch return spring ?
    it hooks onto the lower hole on the pedal arm
  3. Ian Green
    Ian Green Member
    Antrim
    It seem's very heavy for a brake light return spring but i will check later
    What shape of spring?
  5. Ian Green
    Ian Green Member
    Antrim
    at a guess half inch mabey 3 quaters thick and 3 - 4 inches long
  6. Ian Green
    Ian Green Member
    Antrim
    Definitely not the rear brake return spring
  7. XJ550H
    brakeswitch.JPG brake light spring or pedspring.JPG rear mc spring
    are in those areas
  8. yamrider
    yamrider New Member
    preston uk
    it doesnt clip on the silencer does it ?
  9. Ian Green
    Ian Green Member
    Antrim
    Not anywhere i can see 4 into 1 Motad
  10. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    Kickstand spring?
    Center stand spring?
  11. Ian Green
    Ian Green Member
    Antrim
    I can post a picture but i don't know how
  12. Ian Green
    Ian Green Member
    Antrim
  13. Timbox
    What is right below the spring? Looks to be an exhaust that has a bracket with a hole in it. The obvious place to go?
    Ian Green likes this.
  14. bensalf
    yorkshire ,england
    that little bracket the spring is hooked on ,is where the brake pedal return spring should anchor, its on the back of the footrest hanger (right)
    maybe you've got another spring ,anchored somewhere else, but thats where it should be anchored
  15. Ian Green
    Ian Green Member
    Antrim
    For all those who said brake pedal return spring you get the gold prize everybody else thanks for taking the time and the advice. Spring on just had first ride surprisingly good for a 31 year old bike gearbox is very smooth only downside is it's a bit lumpy i suspect carbs so in a couple of weeks they shall be getting ultrasonicaly cleaned. Thank you all you have put a hugh smile on a late 40's man
