Strat's 85 Maxim project bobber
Discussion in 'XJ Modifications' started by strat, Aug 23, 2009.
  1. strat
    strat Member
    Williamsport, PA
    Re: Strat's 85 Maxim project
    i've gotta do some playing with the bike but i'm not sure the spring posts are going to work the way I'd hoped.
    I may have to go with weld on tabs...
    pulled the front fender for giggles and also picked up a new set of chrome turn downs to run on the bike again.
    old pic of the bike with my last set of chrome turndowns...
  2. strat
    strat Member
    Williamsport, PA
    pretty sure I'm going to run the 2" springs on a set of homemade studs. (aka nuts and bolts mounted through the rails)
    mockup pic... will buy nuts/bolts in the next day or two
    mounted my old rear signals on the bike and started to play with the front signals a bit. the housings I have for the front are a single wire style that grounds through the housing but the factory mount does not have a good ground. I believe i'll be modding them into a 2 wire. for now the front and rear signals will be a different style. (rears cost me over $70 while the fronts were around $20) eventually i'll pickup a matching set.
    and a few pics from my ride this evening.
  3. strat
    strat Member
    Williamsport, PA
    mounted up one of the chrome turndowns. hoping to get the other done tomorrow along with getting the seat springs bolted on.
  4. strat
    strat Member
    Williamsport, PA
    seat is sprung. :)
    finishing wiring on the signals this weekend... wifey has given me the ok to FINALLY order some forward controls too. :) TC Bros, here I come!
  5. skillet
    skillet Active Member
    SW TN
    NICE!!!
    skillet
  6. strat
    strat Member
    Williamsport, PA
    buttoning up the wiring tomorrow.
    forward controls should be here Weds. :)
  7. strat
    strat Member
    Williamsport, PA
    quick pic of my new wheel
    and the bike decided that it didn't need one of the side covers today while I was out for a ride...
  8. TonyHes
    TonyHes Member
    Brampton, Ontario. Canada.
    Fazer front wheel... This will change riding characteristics... check the maxim x webpage... I believe its not a handling upgrade.... Looks is another thing.
  9. strat
    strat Member
    Williamsport, PA
    I am aware it will change how the bike rides. Most have noticed very little difference in ride. My bike isn't exactly a corner Carver anyways so I'm not too concerned. Can always put the stock wheel back on if I don't like it. :)
  10. Tibber
    Tibber New Member
    Farmingdale, NY
    I love everything you've done/are doing to this bike (except the apes - not my style), so good luck with the rest.
    Where did you get that rear fender?
    And let me know how those forward controls work out, so far the cramped frame is the only thing on the Maxim I don't like!
  11. strat
    strat Member
    Williamsport, PA
    Rear fender is just a standard trailer fender from tractor supply.
  12. strat
    strat Member
    Williamsport, PA
    got the TC Bros forward controls pretty much buttoned up on the bike. I'll try to get some pics tomorrow. :)
  13. strat
    strat Member
    Williamsport, PA
    a few pics from today's ride on the motorcycle miracle tour
    and with my buddy's bobbed s40
  14. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    Which forward controls did you buy? I want to get some but not sure which to buy. I have an 85 xj700.
  15. strat
    strat Member
    Williamsport, PA
    tc bros is who I bought the controls from. they are for the xj650. you need to buy different hardware to mount them as the 650's have threaded holes in the frame where the 700 has through holes and you will need spacers to clear the outer header tubes. (i bought an extra set of nuts to use as spacers)
  16. Orange-n-Black
    Memphis Area
    Lookin' good.
  17. strat
    strat Member
    Williamsport, PA
    Ordered a new set of turn signals for the front, an electronic flasher, and a set of mirrors.
  18. strat
    strat Member
    Williamsport, PA
    went for a short ride with a buddy up to a local lake and grabbed a pic or two...
    still have to install my new turn signals and flasher. mirrors will probably wait till I do some more clean up on the handle bars. i've got some ideas i've been toying with to clean up the bars.
  19. strat
    strat Member
    Williamsport, PA
    New mirrors
  20. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Where'd you get those forward controls? Sweet ass clean bike b.t.w.
