Stripping a gas tank....
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, Sep 29, 2016.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Best thing to remove original paint?
    aircraft paint remover , liquid or spray. its harsh and will burn you if you do not wear heavey thick "rubber" gloves and a resperator should be used for the fumes.
    you could just sand it smooth and repaint no real need to take it down to the metal.
    mrdawson and Evan Hawtrey like this.
  3. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Thank you!
  4. JHM
    JHM New Member
    Langley BC
    The active ingredient in aircraft paint stripper is frequently methylene chloride, some of the furniture strippers available at home improvement stores use this. It is nasty but it works.
