Stuck Brake pistons
Discussion in 'XJ Technical Chat' started by avengingllama, Feb 21, 2009.
  1. avengingllama
    avengingllama Member
    Columbus, Ohio
    Hey all,,,,rebuilding my brake calipers (thanks to Chacal's speedy delivery =) )but am having trouble getting the pistons out. Any advice?
    Thanks =)
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Take them off the fork one at a time and use the brake handle to pump out the piston for one of them. Rebuild, install, bleed, take off the other and do it again.
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Compressed air with a blow gun will work. Remove the caliper from the bike. Blow air into the brake line hole besure to make a tight seal. Use a thin pice of wood to protect the piston as in will pop out the caliper with great force. If you do not have compressed air a grease gun will work. Just pump grease in though the open bleed screw and plug the hole for the brake line.
  4. kontiki
    kontiki Member
    Columbia, SC
    I have used compressed air successfully but one was so stuck I had to use a grease gun. That worked like a champ and is the safest method but makes a big mess of grease. If you use compressed air make sure you stuff a rag into the caliper to cushion the piston when (and if) it comes blasting out (watch your finger(s).
  5. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I've used compressed air with great success. like the guys said above though watch your fingers the piston will come out like a rocket! If you don't have a blow gun, I use an old tire valve stem. Works perfect
  6. avengingllama
    Columbus, Ohio
    OK guys....I just got done putting the brake system back on the bike to try using the mc to push out the piston but it did not work....I don't have a grease gun or an air compressor (can't tell I just started getting tools can you? lol) so any other ideas? or should I just bite the bullet and get a grease gun?
  7. Hillsy
    Hillsy Member
    If you're going to buy anything buy a little compressor with a blow gun. It'll be worth it's weight in gold next time you clean your carbs :wink:
  8. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I've used a plug in tire inflator, I've done it 4 times to different bikes and it always works - They run about $10 -20 at wal mart or canadian tire etc
  9. Polock
    link
    do not read this post, do not try this, this mans a fool i tell ya
    but it does work :)
  10. bill
    bill Active Member
    Raleigh, NC
    Hey step 1 of the 12 steps - admit you have a problem :D :D :D
  11. bigfitz52
    I used a propane torch and giant vice grips, ruined the piston but the caliper is fine. TRIED compressed air and grease to no avail. Maybe I shoulda tried Polock's method, but in my garage... I'd have a new skylight and still need a piston.
  12. wizard
    Was this another Kroil failer, Fitz?
  13. frankenbike
    frankenbike New Member
    michigan
    avengingllama,
    You may still have air in your b-lines. Bleed them & try again. Mine were really stuck & air would not budge the pistons. the b-fluid built up enought force, via the m/c and it worked!
    be VERY carefull using compressed air; keep your fingers/body clear of that piston as it could do some serious damage if it hits you.
  14. avengingllama
    Columbus, Ohio
    Ace.....You have mentionted the one tool I already have =)
    Polock...that does look like the kind of craziness that I would attempt in an "inspired" (aka....desperate) state
    Think I may try that in the next couple of days after rebleeding and pumping the brake lines (air compressor, not steam ;) ) Thanks for the suggestions, I know one of you guys will have the answer and I will send a SHINY new quarter to whoever it is. And I work for a vending company, so I can get shiny quarters .....lol
