Suzuki bandit smokes
Discussion in 'Other Motorcycles' started by tjm, Apr 9, 2017.
  1. tjm
    tjm New Member
    missori
    just push bandit 1200 very cheap. Bike will not idle but sounds good when running. Carbs are leaking gas from float bowls and white/ gray smoke comes out of exhaust while running. My plan was to clean carbs and replace float needle seats To see if that fixes problem but since it's smoking wondering if I should do compression check on cylinders first. Anyone have any thoughts ?
    1. I always do a compression check BEFORE I buy. You bought a runner, so the compression is good enough anyway.
    2. White/grey smoke is a combination of the extra fuel, and condensation. I'tll clear up once you fix the carbs and run the engine up to temperature.
    3. Find a Suzuki Bandit forum so you can get expert advice on the little things that are unique to that model. Unless someone here owns one, all we can give you is general advice.
    Jetfixer likes this.
  3. tjm
    tjm New Member
    missori
    Thank you for the information k moe. I have a seca 550 I got back on the road last year after it had been sitting for 20 years. Without this forum I don't think I would have been able to get it done
  4. Timbox
    I used to have a 03, loved it but just had too many bikes so she had to go down the road. There are lots of forums out there to help you.
  5. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
