Suzuki gs 750 carbs on a 650 maxim
Discussion in 'XJ Modifications' started by matthew fitzpatrick, Sep 21, 2016.
  1. matthew fitzpatrick
    matthew fitzpatrick Member
    wirral
    Has anyone tried to put gs750 carbs on a maxim as mine are completely wrecked if so any tips or advice ?
  2. Simmy
    spacing is all wrong, they won't fit.
  3. k-moe
    Unless the carb bodies have been crushed, you can rebuild what you have.
  4. matthew fitzpatrick
    wirral
    2 mixture screws seized and rounded gently drilled into them used an easy out 1st one sheered half its thread out , when new one went in just wouldnt tighten only knew it wrecked half the thread after 2nd one had to drill out as was completely wrecked !! Tried tapping out a new thread before no joys so only chance left is a helicoil which i havent got and honestly do not want to undertake at the moment so its either new carbs or cheap replacement
  5. k-moe
    There are plenty of XJ carbs on Ebay. Both XJ650 and XJ750 carbs are the same; just jetted a bit differently. Some members here have stashes of carbs. Might be worth placing an ad in the wanted section.
    Now as for the screws. Are you sure you were drilling into the mixture screws? I've never come across a mixture screw that was so stuck that it'd shatter an extractor. Heck, I can't even imagine being able to get an extractor small enough to use on them, and I know there isn't room enough to drill for an insert since they are so close to the enrichment circuit.
    So, I'm curious is all. Pics. I neeed pics! :)
    Alan63 likes this.
  6. matthew fitzpatrick
    wirral
    It was tight i wont lie i keep thinking about wadding it out with epoxy metal shoving it in measureing the gap from correctly set 2&1/2 turns an leaving it be
  7. matthew fitzpatrick
    wirral
    I am considering a 4 into 1 carb conversion , using a 1.5 inch sub mgb carb creating a manifold with a scavange style set up and removing the air box and fitting either a mushroom od pan cake in place of the air box with a proper cold air intake set up
