Tach?
Discussion in 'XJ Technical Chat' started by LittleR640, Apr 5, 2008.
  1. LittleR640
    LittleR640 New Member
    Gettysburg,PA
    I was riding today and my tachometer just stoped reading. My bike still runs fine, but i was wondering if anyone knows what the problem would be?
  2. CharlesCollins
    CharlesCollins Member
    Milwaukee, WI
    Could be a loose/stuck tach cable. Did you check to make sure the cabe is still screwed in all the way?
  3. LittleR640
    Gettysburg,PA
    yea, the cable is screwed in all the way, and the tach shows nothing
  4. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    sounds like you might have snapped the cable, happened to me on my dads CB750
  5. Robert
    Another possibility is the meter movement coil burned out. Check resistance across the coil with the pigtail disconnected. If you don't read continuity, it's done. It might be possible to fix (I repaired one just this past year) but usually they are done for by then. Best of luck, let us know what you find.
