Tachometer needle broke
Discussion in 'XJ Technical Chat' started by REUBEN, Jun 4, 2017.
  1. REUBEN
    REUBEN 1985 XJ700N (NOT PICTURED) Premium Member
    Midwest United States
    Got engine running. During carb sync, the damn needle broke! I have a mech tach in the parts pile. Could I use that to repair somehow?
  2. Jetfixer
    The needle is a press fit you have to carefully pull it off without bending shaft.
  3. k-moe
    Superglue and a flat toothpick. Cut the toothpick to act as a backer. Glue it in place and put the broken needle back together. Repaint if desired.
    REUBEN likes this.
  4. REUBEN
    I'll try the tooth pick repair first. I sure I'll just damage the other needle attempting to remove and install.
