Taking rust off chrome
Discussion in 'XJ DIY How-To Instructions' started by gman, Jul 14, 2011.
  1. gman
    gman Member
    Grand Rapids Mi
    A cool tip I found on another bike restoration forum.
    Oxalic acid the main component in wood bleach and deck prep.
    The stuff eats rust off chrome like it's candy.
    I picked up a gallon of deck prep last night. I took a guess and mixed 1 to 1.
    Did a test with the chrome parts from the air box. Completely covered in rust.
    Dropped them in the bucket two hours later totally free from rust. It won't do anything about pitting.
    I am still damm impressed. I wonder if I could get away with dunking the mufflers in it
  2. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    1 part deck prep to 1 part what? This sounds pretty awesome I have a lot of dunking to do if this works.
    - Matt
    P.S. I wonder if C.L.R. would work well with that stuff... http://www.jelmar.com/CLRbasic.htm ?
  3. Polock
    you can get Oxalic acid on ebay and mix it as strong as you want.
    it's a white powder and a little goes a long way. i mixed 1/4 cup in a gallon of water and found a nasty old screwdriver to test, took 2 days but it worked
  4. gman
    gman Member
    Grand Rapids Mi
    I mixed it with water. I am still learning with this stuff. I mixed it strong cleaned the handle bars in a day. Watch it though leave it in too long and things start to turn green. Then you have to rub off the green. Do wear gloves it will make your fingers sting if you touch it.
  5. HirsuitHeathen
    South Jersey
    Brasso has oxalic acid in it and works like a charm. It has a horrible smell, but it works! Used it instead of wet sanding all the brass parts in my carbs. It's all shiny and like brand new now.
  6. gman
    gman Member
    Grand Rapids Mi
    I am lazy. Mix up a batch and leave the parts to soak.
  7. HirsuitHeathen
    South Jersey
    Ha ha I feel ya.
  8. ProfessorBooty
    ProfessorBooty Member
    Columbus, Ohio
    I bought some oxalic oxide (sold as wood bleach) powder from Ace Hardware and mixed it two scoops (included) to one gallon. I used it on my carb hats and an old headlight bucket and bezel. I left them in there for 36 hours and they came out great, the rust was all gone.
    Definitely wear gloves, it starts to burn fairly quick if you don't.
  9. Bomonghani
    Bomonghani Member
    Indiana
    Ever try soaking in a bath of coke? - reason I never drink it anymore...
  10. hogfiddles
    Can't blame you there.....I wouldn't drink coke after I soaked in a bath of it either. That would get expensive and besides, all the fizz would be gone by the time I'd be needing a drink anyway. Of course, those little bubbles would probably feel invigorating for a little while..............
    Dave
  11. dwcopple
    dwcopple Active Member
    bay city, michigan
    I did my head pipes in Diet Coke for a day and scrubbed off the remains with aluminum foil. Now they shine!!!
  12. doc2029
    doc2029 Member
    Richmond, Va
    Regular coke has more acid than the diet. though all the sugar will leave it a sticky mess. I remember as a kid my dad cleaning the battery terminals on the car with coke...
  13. hennit
    hennit Member
    LaCrosse
    Would it be ok to soak my shocks in a bath of Oxalic acid mixture? Or could it ruin them?
  14. george2524
    george2524 Member
    Maryland, USA
    I have been searching through many different sites looking for info on rust removal also. The least destructive and least toxic method I have found is electrolysis. It uses a low amp battery charger and washing soda, baking soda works also. I tried it on a headlight bucket and it did a great job. I plan on doing my shocks next.
    The concentration of baking soda is one teaspoon per gallon of water. The process is also self limiting.
  15. adrian1
    adrian1 Active Member
    hennit what part of your shocks are rusty? If its the shafts throw them away and treat yourself to a new set!
  16. hennit
    hennit Member
    LaCrosse
    no shafts look good just my springs are nasty looking. would I be able to take off just the springs and do it? How do you get the springs off?
  17. adrian1
    Just send them to a powder coater as is. You need a special shockie spanner to get them off but some wizard on here will have an alternative
  18. itom32
    itom32 New Member
    Hi,i will give you a link to my Honda CB400Superfour homesite in Greece.
    If you are talk about rear shock springs,you can look how i solve the problem,and how i remove the spring from the shock.
    The oem absorver on Honda CB400superfour is Showa.But it is possible to solve your problem with the same way more or less.
    Im not expect from you to understand Greek,but if you dont understand something from the photos and you want to ask something,im here to help.
    The link: http://www.go4it.gr/smf/index.php?topic=3027.90
    And sorry for my bad English. :roll:
  19. itom32
    itom32 New Member
    Ok i was so curius about the use of cola as rust remover and i did that test.Before:
    Chemichal washing
    After only two hours: 8O only a light brushing with a hard dental brush
    FtUp likes this.
  20. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Now was that using regular Coke, Diet Coke, Coke Zero, Cherry Coke, Vanilla Coke, anon, anon. :roll: :roll: :D
    Been.jamming likes this.
