Tank lining failure
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, Sep 17, 2016.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Not sure what was used...is there a chemical that will eat it off? And what should I replace it with? Any tips r appreciated
    Methyl Ethyl Ketone (take due care and wear the appropriate PPE in a well ventilated environment). Reline with Caswell's or any other epoxy liner.
    Jetfixer likes this.
  3. Jetfixer
    I like Redcoat...35.00$ from Oreilly auto parts
  4. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    What's the process on mek
  5. Jetfixer
    Drain tank , remove tank from bike , remove petcock, remove sending unit...fabricate a cover for sending unit, petcock...as long as you can make it water tight...pour 2 pints of MEK in slosh it around let it soak, for 20 min , slosh it around again let set 20 min ...repeat look in filler neck see if old liner is coming off ...with a pick or long screw driver see if you can peel it.....if it is starting to come off drain mek at petcock location...let it air out for several days...the use your liner of choice
  6. Polock
    don't replace it with anything unless it leaks.
  7. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Well here's the deal... I had it soldered....it currently isn't leaking...wanna have tank painted after riding season.. so I figured line tank before I paint it....just to be safe and not have to do it with a painted tank....
  8. Polock
  9. k-moe
    Unless they made major changes in what Redcote is made of, it's prone to failure.
  10. yellow_yellow
    yellow_yellow Member
    Ann Arbor, MI
    Bump
    Sealing my tank over the winter as I found a pinhole leak while it was stored (puddle of gas on my garage floor was a pretty big indication).
    It had been lined by idiot PO but it has obviously failed. Is putting some washers on a piece of wire with the MEK to knock things loose a good idea?
  11. Jetfixer
    If you can still find a radiator shop and you can repaint your tank, they can usually "hot tank" your tank and can braze tank if it is a pin hole and you can line inside of tank with a good sealer Caswell ,Kreem, or one I like Redcoat ...or find a used tank and repaint it .
  12. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    MattiThundrrr likes this.
  13. hogfiddles
    I look for another much better tank
