Tank swap?
Discussion in 'XJ Modifications' started by Turbobob23, Aug 1, 2017.
  1. Turbobob23
    Turbobob23 Member
    Fredericton N.B. Canada
    Anyone ever try swapping the Virago tank on to the XJ700 for fit? Will it even work? Does the fuel petcock line up?
  2. steber
    steber Active Member
    Scranton, Pennsylvania
    Virago is a very general term, what year are you talking about? I put a 2002 xv250 virago tank on my bike. Tunnel is slightly narrower, and the tank itself was shorter than my xj550 tank. I was able to swap my petcock and my gas cap over to the xv250 as a direct swap though.
  3. hogfiddles
    Most people ask because the '84+ xv700/750/1000/1100 tank looks right like the 85-86 xj700/750/X tanks.
    BUT
    1. The tail is a different shape-- round rather than squared, round hole rather than oval.
    2. The 'shoulders' share a bit more 'pointy'
    3. The tunnel is much narrower
    4. The larger xv's also had two petcocks, AND a reserve tank tucked in below the seat, along with a fuel pump to pump from the reserve tank......
    Long and short, if you have metal-working skill you can make it work, but i's gonna be time and $ consuming
    Dave
