Tapping Carb Threads?
Discussion in 'XJ Technical Chat' started by LPKirby, Jan 7, 2021.
  1. LPKirby
    LPKirby New Member
    Toronto, Canada
    I'm in the process of rebuilding and cleaning the carbs and want to clean up the threads. I can't seem to find thread chasers in sizes under M6. Would it be acceptable to use a tap instead?
    No. Cut a groove in a screw and use that. A tap is going to cut the metal instead of just cleaning out the crud.
    Franz and LPKirby like this.
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    How would you go about cutting a groove? Sound useful.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    I've used a file to do just that.
  5. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Run a nut up the bolt, use a hacksaw or junior hacksaw to cut the slot, back the nut all the way off. Check with a magnifier that the threads are clean before using it.
    k-moe, LPKirby and jayrodoh like this.
  6. k-moe
    I use my Dremel and a cutoff wheel. I don't cut a slot through the diameter; I cut a groove along one side just deep enough to hit the minor diameter of the threads.
    The groove gives the crud somewhere to go.
    cgutz and LPKirby like this.
  7. tabaka45
    Brunswick, Georgia
    So, if I understand you basically have a flat spot in the threads?
  8. k-moe
    No. A groove similar to what you'd see on a tap.
    I suppose a flat spot would work just as well though.
  9. k-moe
    LPKirby likes this.
  10. Polock
    good luck doing that with a 4mm carb screw
  11. k-moe
    I have done. But making a flat on one side would be easier.
  12. tabaka45
    Brunswick, Georgia
    Looks like something I may try just for the fun of it. it would seem that keeping the cut threads clean and precise would be the main consideration.
  13. k-moe
    A quick touch up with a thread file is usually needed.
    You can make a chase out of nylon screws as well, but I haven't done that for anything smaller than 6mm.
  14. LPKirby
    LPKirby New Member
    Toronto, Canada
    Any idea how to touch up the threads on a M3 screw? Can't seem to find a thread file available in 0.5mm pitch.
  15. k-moe
    Wire wheel at that size. Or a small triangular file. Or a whetstone. or put a nut on it before making the cut and the nut will deburr it when removed.
    LPKirby likes this.
  16. Polock
    lets just start all over again
    yes it would be. just be careful and turn it with your fingers, no tap wrench. get a set and use the plug tap unless there's something on the other side the tap will hit, if so use the bottom tap.
    you won't remove any meaningful metal with finger power
    LPKirby likes this.
  17. a100man
    a100man Well-Known Member
    Bedford, UK
    I think it also depends on the quality of the TAPs - someone gave me an obviously Chinese set once that's gone straight in the bin - even with the naked eye I could see burrs. A proper precision TAP has to be good doesn't it?
  18. Polock
    someone doesn't like you :)
    jayrodoh likes this.
  19. jayrodoh
    jayrodoh YimYam
    Cleveland
    Reminds me of the little screwdriver set I get almost every year from one of the kids Santa Shop at school. He goes in with $5 and I get a little set that says DAD on it. At least this year it had a bottle opener on the end :D
