The Project So Far...'82 XJ650R Seca
Discussion in 'XJ Technical Chat' started by GrooveJunkie, Apr 24, 2013.
  1. bigfitz52
    Back to your ride and tuning observations: if you've still got a hanging idle, your sync is still not spot on or you've got a wonky float level. If you're "bluing" one pipe, then that cylinder is definitely running leaner than the others and it is probably the culprit.
