The (R) factor?
Discussion in 'XJ Technical Chat' started by Door dude, Jun 25, 2020.
  1. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Has anyone bought the NGK R BPR7ES spark plugs? Do you know what the R stands for?
  2. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    resistor
    if you have resistor wires, don't get an R plug
    if you do... the opposite
  3. Door dude
    If I had resistor wires what would happen if I put the R in ?
  4. raskal
    twice as much resistance than should be there
    but I really have no real world experience here maybe someone else will add knowledge here
  5. SQLGuy
    SQLGuy Well-Known Member
    Longer burn time, weaker spark, maybe hard starting.
    Fact is, you don't have resistor wires unless you've installed them yourself via coil surgery, or installed aftermarket coils. You do have resistor caps, though. OE calls for non-resistor plugs. In some places they are not available. In some places, or so I've heard, resistor plugs are actually mandated by law.
    In most cases, resistor plugs seem to work just fine with the resistor caps. I'm guessing it doesn't make enough of a difference under well-tuned conditions. It might make a difference with other mods, and when things are less in-tune relative to factory specs (too rich or too lean).
    Door dude likes this.
  6. Door dude
    My bad, I should of been more specific. I do have resistor caps on 2 &3 but not on1 &4 not sure why. Maybe by design ?
  7. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Mine are like that too. I think I use resistor plugs with the non-resistor boots.
  8. Door dude
    I put 4 new resistor plugs in and went for a 25 mile ride, it ran good, took the plugs out and 1&4 were dry black and 2&3 were dry and black mostly, the white part was tan. ???
  9. Door dude
    My bad on this post I should have said that I was in the process of dialing in the carburetors I had the air/fuel screws set at 2.5 turns out. When I went for a ride.
  10. SQLGuy
    This is not by design. Design is 4.7K or 5K caps on all cylinders. They're different model caps, as the outer ones are 90 degrees and the inner ones are 120 degrees. Do you have original coils, or has the 1/4 been replaced at some point?
  11. Door dude
    Original coils. My 83 Midnight maxim is the same.
  12. Door dude
    My inner ones are 90 degrees also.
  13. XJ550H
    you can use non resistor caps and then use resistor plugs. that way you have refreshed the resistors when you replace the plugs.
