The simplest YICS Tool?
Discussion in 'XJ DIY How-To Instructions' started by Dario Archer, May 18, 2022.
Tags:
  1. Dario Archer
    Dario Archer New Member
    Western Australia
    Hi all,
    Hi from Australia.
    I have recently purchased an 83 XJ900R as a project for my retirement and have read with interest the first and against regarding blanking off the YICS system when synchronising carbies.
    For what it's worth and if has been done before, my apologies to the original author.
    I purchased a length of circular soft rubber of 13 mm from our local rubber shop. I then pierced it with so light gauge wire, okies up the rubber and with some pressure pulled it through successfully.
    cheers Dario
  2. Dan Gardner
    Minneapolis, MN
    @Dario Archer , that gets pretty hot when the engine is running. Will that rubber survive the heat?
    Also, there is a fair amount of debate as to whether the block-off tool is actually needed or not.
    cgutz likes this.
  3. Dario Archer
    Western Australia
    Good point Dan, no idea on the tolerance for heat, I may end up scraping out goop☹️
  4. Dario Archer
    Western Australia
    I just put a lighter on a section and whilst it caught fire when the flame was held against it for a few seconds, if you left it to heat up without the flame hitting it, all seemed to be ok. How long it would last on a running engine is another matter of course.
  5. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I have had my XJ550 since new, I have never used a YICS tool for a running synch, and no issues.
    Timbox and Franz like this.
  6. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Even the original YICS tool rubber will start to melt if left in too long. You remove it in between runs to let it cool off a little between adjustments.
    You'll want some brass clean out brushes to get that gunk out, and picks to clean the passages when they gunk up with rubber. Good idea anyway if it needs cleaning.
    YICS tool takes one of the variables out of the equation for syncing. If you're very close, it's not going to make a difference, but if you're way off, it could contribute to chasing your tail. It's a process, with a bench sync, pilot adjust, sync, pilot adjust, until it runs like a sewing machine. You can get lucky with the first adjustment, but since there are 8 variables (4 pilot, 3 sync, and 1 idle screw) it's better to be methodical.
  7. Dario Archer
    Western Australia
    Thanks for the additional info. It should turn out to be an interesting exercise ManBot13 Cheers
