Thoughts on what to do.
Discussion in 'XJ Technical Chat' started by Metalliccurrent, Mar 17, 2017.
  1. Metalliccurrent
    Metalliccurrent Member
    OHIO
    Sorry let me correct. The video is just me horsing around with it 2.5 turns. The exhaust is on now and it's 4.5-5 turns. If not throttle is sluggish or hangs and it lops at idle. Maybe I should go up from a 43 jet. Or learn to stop fixing if not broken Thought?
    Remind us what you have for an intake and exhaust.
  3. Metalliccurrent
    OHIO
    pods for intake. Exhaust is 2to1. I'd guess if I put box back in I could turn it back a few. But she looks so sexy with pods:D the carb rebuild kit I installed is for a xj750. 122 main 43 pilot. Also came with a 112 which I didn't use. Not sure what that size was for.
    In any case you're lean.
    Not lean enough for the pods to cause that high of an idle on their own.
    Break the rack. Replace the seals.
    Looks ≠ go.
    If you want go, you'll need the airbox.
    If you want looks you'll need to rejet for pods after you replace the throttle shaft seals and check for any other intake leaks that may be present (spray carb cleaner is your friend).
  5. Metalliccurrent
    OHIO
    I have considered putting air box in and seeing if their is a different. I've already replaced throttle shaft seals and sprayed intake boots and sides of carbs looking for a leak.
  6. k-moe
    I'm backing up because I misread. That 43 pilot is stock. It'll work great with the aribox, otherwise you need to rejet (both pilot and main).
  7. chacal
    The #122 main jets are way too large for this engine, pods or (especially) otherwise. Stock jets are #107 for an airhead XJ700. #43 pilots are too large also (stock is #36.5).
    If you're running lean with these sewer-pipe sized fuel jets then there is something else going on...........
    Metalliccurrent and k-moe like this.
  8. k-moe
    Doh.. forgot that this is a 700 and not a 750
  9. hogfiddles
    May be some sewage in there.....
    chacal likes this.
  10. Metalliccurrent
    OHIO
    Ok so we are saying it's running lean based on fact that pilot mix is 4+ turns out right? I left 205#,50# air jets in top under diaphragm. Also based on cheats from church xj 700 carb don't use air compensators. It's 34 degrees here and this morning is first time she's started on her own.In theory I could have a fuel jet the size of a manhole cover but if I didn't put a proportionate size air jet it wouldn't allow negative pressure (vacuum) to draw fuel from bowl right? Thanks for replying I truly value you opinion.
  11. hogfiddles
    No.....were saying you're running lean because your sucking in too much air somwhere
  12. k-moe
    With the jets you have the bike should be running rich, even with the pods (note Chacal's post and my response).
    You have a vacuum leak.
  13. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    That sucks. :D
    Lightcs1776 and Metalliccurrent like this.
  14. Metalliccurrent
    OHIO
    I put color tune plug in tonight to see what I had. So determined that carbs 1 and 4 would never give me a (rich) yellow flame(at idle). Throttle shaft seals right. Soaked them with carb clean then starting fluid with no change in engine sound/rpm or flame color. Carbs 2-3 respond correctly when adjusting. These carbs are cursed.
  15. chacal
    The pilot circuits are partially blocked. Try the colortune on those cylinders again, but this time bump the choke on just a hair, see if you can get a yellow flame. The choke circuit is entirely separate from the pilot circuit and thus can be used to check whether it is a no-fuel-supply issue vs. an air leak.
    rocs82650 and k-moe like this.
  16. Metalliccurrent
    OHIO
    Good thinking chacal.
  17. Metalliccurrent
    OHIO
    Took off carburetors and disassembled carbs 1-4 for a look at pilot passages. Used a small piece of wire to fish around, clean air and fuel jet with torch tip cleaner. Blasted a whole can of brake clean through passages and then blew out with shop air. Tried to catch any debris on a white rag so that I could see the offender. Nothing visible on rag? Reassembled and adjusted carbs, found that they respond like they should with mix getting rich and then leaning as I turn them in. Took her for a run and she throws me back in the seat.:eek::confused: Thanks for all the help guys.:)
    k-moe and chacal like this.
  18. Metalliccurrent
    OHIO
    Hey guys I got a set of carbs for a xj700 off ebay for cheap. When I recived them there a little different than carbs off the 650. they have a t fitting between 1-2 3-4 above bowl which I assume is a overflow?. Also have a hose barb on each carb LH side of throat,engine side, what is each of these connections for? I can post a picture if needed. Read a how to on xj forever (naked carb) that stated it's a xj700 California carb. Thanks guys
  19. Toomanybikes
    Tsawwassen bc
    The will look like these. 4 hoses off bodies are vent to float chambers just hangs down between intake boots and yes 2 overflow tubes go down back of engine and stop just below rear frame cross member
    Metalliccurrent and Stumplifter like this.
  20. Metalliccurrent
    OHIO
    Thanks for info. Those carbs you posted sure are clean,very nice.
  21. k-moe
    You'll need to do some experimenting with the jetting on the XJ700 carbs. They are not only jetted differently than the carbs for the 650, they have a different throat size (33mm as opposed to 32mm). My recommendation is to sell them, and find a set for a XJ650 or Xj750 (all that needs swapped to use 750 carbs is the main jets). They can be made to work, but I don't think it's worth the amount of time that would be involved vs. rebuilding and swapping in a set of HSC32 carbs.
  22. waldreps
    waldreps Active Member
    Henning, MN
    His motor is an XJ700 and he just got some carbs for an XJ700. Wouldn't that be the ideal situation to have? Shouldn't he just rebuild the XJ700 carbs to stock and use the stock airbox and he'd be good to go, right? Or am I missing something?
  23. k-moe
    I missed that bit. My mind must be turning to mush. The last I remember he was swapping in a 750, but I see now that I missed a post.
    waldreps likes this.
  24. waldreps
    Henning, MN
    k-moe, you help so many different people in so many different posts that I'm surprised you don't get mixed up more often! Thanks for helping everybody!
    k-moe and Stumplifter like this.
  25. Metalliccurrent
    OHIO
    Right waldreps, the engine I thought was 750 is a 700 and the carbs I bought are from that exact engine. I am curious to see how she runs with stock carbs and air box. Did all the xj700 carbs have all these extra fuel vents or is this one 'special". What happens if I just put vacuum caps on them or leave hoses off?
  26. waldreps
    Henning, MN
    I'm not real familiar with the XJ700 carbs so I'll let somebody who knows better get back to you.
  27. k-moe
    The extra hoses are float bowl vents/overflows. If you cap them a low pressure area will form in the float bowls and the bike will eventually stall from fuel starvation. The hoses are a good thing to have. If a float needle should leak (or the bike lie down for a nap) fuel will spill onto the ground instead of into the crankcase.
