Throttle Shaft Seals
Discussion in 'XJ Technical Chat' started by -Azrael-, Apr 22, 2011.
  1. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    So, I did a Valve Adjust/Carb Sync today...
    The valves were so far off it isn't even funny...
    First Check:
    Cyl 1:
    Intake: .05mm - 275 shim
    Exhaust: .05mm - 260
    Cyl 2:
    Intake: .10mm - 280
    Exhaust: .17
    Cyl 3:
    Intake: .10mm - 285
    Exhaust: .10mm - 265
    Cyl 4:
    Intake: .8mm - 280
    Exhaust: .11mm - 270
    Set to:
    Cyl 1:
    Intake: .15mm - 265 shim
    Exhaust: .21mm - 270
    Cyl 2:
    Intake: .14mm - 275
    Exhaust: .17
    Cyl 3:
    Intake: .12mm - 275
    Exhaust: .18mm - 255
    Cyl 4:
    Intake: .14mm - 270
    Exhaust: .19mm - 260
    Gotta keep an eye on Cyl 3 intake.
    Do any of you think the .12mm on Cyl 1 Exhaust is a problem?
    She sounds a lot better and we'll see how she runs tomorrow.
    The only odd thing I that there was what seemed like oil in the YICS passage. Is that normal?
    Cheers
    Dave
  2. Robert
    "The only odd thing I that there was what seemed like oil in the YICS passage. Is that normal?"
    I've noted this on a few of mine and chalked it up to leaking valve seals and coking. I'd like to hear a few other ideas fellas...
  3. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    Our Yamaha tech actually thought that whilst there may be some oil in the passage, it is more likely just gas that settles inside and then has been boiled and re-boiled giving it the dark, oily viscocity. But that was just his specuation as it has been many years since working on these bikes.
    Cheers
    Dave
  4. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    So, she is running much better after doing the Valves and Sync but still slightly hangs. Such I have ordered all the parts for carb rebuild from Chacal. Tore my spare carbs apart today and have some questions about if certain parts can be re-used...
    Float Needles: The bike wasn't flooding before so I would assume they work, but there is a slight bump on them. Can I use these or do I need to get all new float assemblies?
    Enrichment: Do I need to replace the boots on the top of the plungers?
    Mains: I took the jets out a long time ago. These are the washers that go under the main jets yes?
    Going to take the carb bodies to work to run through the agitator once my parts come in with the JIS screwdriver. Also re-jetting the mains while I'm at it as I have an essentially open exhaust.
    Also got a colortune so I can set the idle mix right when they're done.
    Does using a colortune on a cylinder that's burning oil damage anything?
    Any notes or input from anyone about this rebuild?
    Other tips I am probadly forgetting?
    Cheers
    Dave
  5. Robert
    The float needles are probably history. New ones are indicated.
    The jet washers are reusable, just clean them up.
    The enrichment plunger boots are unobtainium, treat them well and preserve.
  6. cutlass79500
    lawrenceville georgia
    I agree with robert. The needles are shot see the shiny part where it rubbed off the viton (i think thats what its called) that should be smooth with no bumps. They might not be leaking right now but they will. Hopefully you have them marked the wear marks are from it seating. If you don't put it back in its corresponding seat it will never seat again properly
  7. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    May have a lead on some plunger boots, will try to replace them as they didn't come off very easy...
    I have kept everything short of the choke plungers seperated into which body they came from. Will look into replacing them but might end up using whichever set is better from my old and current carbs.
    Cheers
    Dave
    edit: Scratch that, found some keyster Valve Assemblies in a drawer at work for near free. Will be replacing them.
  8. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    Indeed I have found some new Choke Plunger Boots adn 5 are on their way to me.
    Cheers
    Dave
  9. Robert
    If those plunger boots work, get a part number for us! I'd like a set!
  10. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    I got them from Yamaha themselves. Sounds like I may have almost gotten the last set in North America...
    Cheers
    Dave
  11. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    well looky looky what came in the mail today :)
    Got all the parts needed for a full carb rebuild and tune
    Shaft seals, clips, and shims
    Fuel line o-rings
    Float valves
    Jets
    Butterfly Screws
    #2 JIS for disassembly
    and just for the hell of it:
    Choke plunger boots
    Exhaust gaskets
    So, time to:
    disassemble
    Polish slide bores
    run bodies through the agitator
    rebuild
    Colortune
    Sync
    Jet
    Re colortune and sync
    and then see if my damn idle will work nicely :p
    Many thanks to Chacal!
    Cheers
    Dave
  12. Robert
    I'm drooling...
  13. -Azrael-
    -Azrael- Member
    Vancouver, Canada
    Well, here we go :p
    Step One: Break down... Done
    Step Two: Clean...
    Step Three: Rebuild
    Step Four: Ride?
    Cheers
    Dave
