Tips needed on how to remove speedo cable guide from front fender, 82 XJ650 Seca
Discussion in 'XJ Technical Chat' started by Dave C_61, Apr 16, 2023.
  1. Dave C_61
    Dave C_61 New Member
    Summerland, Canada
    need to remove the guide to refinish the fender, hoping to reuse it but it seems pretty firmly mounted, can rotate it, but no sense at all that its going to pull out. Can these be removed and reused, or do you have to destroy them to get them off the fender?
    thanks!
  2. Dan Gardner
    Minneapolis, MN
    You can just work the bottom out with a flat blade screwdriver. A little silicone or other lubricant might help. Definitely helps going back in.
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    warm it up with a hairdryer first, not too warm though, that should make it pliable enough to "pinch" the rubber in on the inside to get it out
  4. Dave C_61
    Summerland, Canada
    Thanks, a bit of heat did the trick!
