Wanted To borrow a fork tool
Discussion in 'For Sale, Trade/Swap, Wanted' started by Michael R, Feb 5, 2018.
  1. Michael R
    Michael R Member
    Seattle
    The one needed to separate the fork tubes from the lowers stanchions (to replace fork seals). XJ550
    Seattle area.
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    You don't need a special tool. You need a couple extension and the correct spark plug socket (used upside down) which I don't remember the size. Pretty sure a 3/8's will do it.
  3. Toomanybikes
    Tsawwassen bc
    If you have access to air tools ?
    It will come apart without special tool.
    Leave fork springs installed and an air gun will spin out the bottom bolt 99/100 times. Remove dust seal and clip and it's that easy
  4. Polock
    put some heat to it, there's thread lock on it
  5. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Chacal sells the tool. I'd let you borrow mine but I'm on the east coast.
    Otherwise, I second the air tool. Smaller 90 Ft-lb 1/2 or 3/8 inch drive will spin it right out, just make sure to go the right direction. I've been able to do the XJ forks without it, but I've done several other brand motorcycles since that it's been the best way.
    To tighten, I've used the air tool too, but I set it on it's lowest setting and then check if it'll spin with the torque wrench. Up the setting, and check again. When tight enough the torque wrench will click and it won't spin. That's gotten me through a bunch of forks.
  6. XJ550H
    then there is the broom handle
  7. hogfiddles
    Just be sure to shove it where it's supposed to be shoved
  8. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    ...I am not needed here.o_O
  9. Michael R
    Michael R Member
    Seattle
    Thanks folks. I don’t have access to air tools, so I will fabricate a tool myself. Thanks for the help!
