Turn signal issue...... HELP
Discussion in 'XJ Technical Chat' started by Timmy89, Sep 1, 2016.
  1. Timmy89
    Timmy89 Member
    Michigan
    Thanks for looking at my post any help, comments, or thoughts are appricated. If you need any additional info just ask. I can try to take more pics of needed.
    Timmy
    I have a electrical issue with my bike. None of the turn signal works.
    I don't really now anything about electrical.
    I honestly don't know where to start.
    I've look at other turn signal threads.
    How would I go about diagnosing the problem
    I have a 1982 xj650 with a little over 30,000 miles.
    When I bought the bike none of the turn signal work at all. Do not turn on or flash.
    Someone put after market signals on it.
    The bulb size they have in it is a 12v10/5w bulb.
    I was reading on another thread that xjbike that I might need a 27w bulb.
    Pic attached is the bulb p.o had in it
    you are going to need a test light or meter.
    do you have glass fuses?
    you will need a flasher to work with the bulbs you have
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    My stock turnsignals will light up, but not flash unless there are 27w bulbs.
    Using aftermarket, as stated by XJ550H, you will have to replace the flasher, and unless modified, you will lose self cancelling.
